hibba Posted December 15, 2015 Share Posted December 15, 2015 (edited) Hello everyone, i need LISP for continue dimension with aligned option. in reference image, there are 2 options A & B. i am getting option B with continues dimension but i required option A. ;; DimAlignedContinue ;; (defun c:DAC ( / *error* doc point1 point2 ) (defun *error* (msg) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) ) (princ (strcat "\nError: " msg)) ) (if doc (vla-endundomark doc) ) (princ) ) ;_ end of defun (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark doc) (setq point1 (getpoint "\nSpecify first extension line origin:")) (while (setq point2 (getpoint "\nSpecify second extension line origin:")) (command "_.dimaligned" point1 point2 pause) (setq point1 point2) ) ;_ end of while (vla-endundomark doc) (princ) ) ;_ end of defun (vl-load-com) Edited December 16, 2015 by hibba with solving quote Quote Link to comment Share on other sites More sharing options...
rashidsohail13 Posted December 15, 2015 Share Posted December 15, 2015 good i face same problem Quote Link to comment Share on other sites More sharing options...
rashidsohail13 Posted December 15, 2015 Share Posted December 15, 2015 its out of your question but i have other lisp its work for only Polyline on Different Angel. its not work for points to point. only for polyline select one time and create all dimension in once time. (PDIM) (defun c:pdim(/ plSet pLlst vLst oldOsn cAng cDis cPt) (princ "\n>> ") (if(setq plSet(ssget '((0 . "LWPOLYLINE")))) (progn (setq pLlst(vl-remove-if 'listp (mapcar 'cadr(ssnamex plSet)))) (setvar "OSMODE" 0)(setvar "CMDECHO" 0) (foreach pl pLlst (setq vLst(mapcar 'cdr (vl-remove-if-not '(lambda(x)(= 10(car x)))(entget pl))) oldOsn(getvar "OSMODE") ); end setq (while( (setq cAng(angle(car vLst)(cadr vLst)) cDis(/(distance(car vLst)(cadr vLst))2) cPt(polar(polar(car vLst)cAng cDis) (+ cAng(/ pi 2))(* 2(getvar "DIMTXT"))) ); end setq (command "_.dimaligned"(car vLst)(cadr vLst) cPt) (setq vLst(cdr vLst)) ); end while ); end foreach (setvar "OSMODE" oldOsn)(setvar "CMDECHO" 1) ); end progn ); end if (princ) ); end of c:pdim Quote Link to comment Share on other sites More sharing options...
hibba Posted December 15, 2015 Author Share Posted December 15, 2015 thanks Mr. rashid for you suggestion. but I was hoping there was an easier way.. I have to select the lots of points and then pick what side I want my dimensions Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted December 15, 2015 Share Posted December 15, 2015 Here is my version of PDIM... It works for LWPOLYLINE(s) and have option for "INSIDE" - "OUTSIDE"... (defun c:pdim ( / ListClockwise-p ch plSet pLlst vLst oldOsn cAng cDis cPt ) (defun ListClockwise-p ( lst / z vlst ) (vl-catch-all-apply 'minusp (list (if (not (equal 0.0 (setq z (apply '+ (mapcar (function (lambda (u v) (- (* (car u) (cadr v)) (* (car v) (cadr u))) ) ) (setq vlst (mapcar (function (lambda (a b) (mapcar '- b a)) ) (mapcar (function (lambda (x) (car lst))) lst) (cdr (reverse (cons (car lst) (reverse lst)))) ) ) (cdr (reverse (cons (car vlst) (reverse vlst)))) ) ) ) 1e-6 ) ) z (progn (prompt "\n\nChecked vectors are colinear - unable to determine clockwise-p of list") nil ) ) ) ) ) (initget 1 "Outside Inside") (setq ch (getkword "\nChoose on which side to put dimensions [Outside/Inside] : ")) (princ "\n<<< Select LwPolyline(s) for dimensioning >>> ") (if (setq plSet (ssget '((0 . "LWPOLYLINE")))) (progn (setq pLlst (vl-remove-if 'listp (mapcar 'cadr(ssnamex plSet))) oldOsn (getvar "OSMODE") ); end setq (setvar "OSMODE" 0) (setvar "CMDECHO" 0) (command "_.undo" "_be") (foreach pl pLlst (setq vLst (mapcar '(lambda( x ) (trans x 0 1)) (mapcar 'cdr (vl-remove-if-not '(lambda( x ) (= 10 (car x))) (entget pl) ) ) ) ); end setq (if (equal (logand (cdr (assoc 70 (entget pl))) 1) 1) (setq vLst (append vLst (list (car vLst)))) ); end if (if (not (ListClockwise-p vLst)) (setq vLst (reverse vLst))) (while (< 1 (length vLst)) (setq cAng (angle (car vLst) (cadr vLst)) cDis (/ (distance (car vLst) (cadr vLst)) 2.0) ) ; (if (>= (caar vLst) (caadr vLst)) ; (setq cAng (- cAng pi)) ; ); end if (if (eq ch "Inside") (setq cPt (polar (polar (car vLst) cAng cDis) (- cAng (* 0.5 pi)) (* 2.5 (getvar "DIMTXT")))); end setq (setq cPt (polar (polar (car vLst) cAng cDis) (+ cAng (* 0.5 pi)) (* 2.5 (getvar "DIMTXT")))); end setq ); end if (command "_.dimaligned" (car vLst) (cadr vLst) cPt) (setq vLst (cdr vLst)) ); end while ); end foreach (command "_.undo" "_e") (setvar "OSMODE" oldOsn) (setvar "CMDECHO" 1) ); end progn ); end if (princ) ); end of c:pdim HTH, M.R. Quote Link to comment Share on other sites More sharing options...
PDuMont Posted December 15, 2015 Share Posted December 15, 2015 (edited) Hi hibba, See if this works for you. Use it just like the standard dimcontinue: ;; DimAlignedContinue ;; (defun c:DAC ( / *error* doc point1 point2 ) (defun *error* (msg) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) ) (princ (strcat "\nError: " msg)) ) (if doc (vla-endundomark doc) ) (princ) ) ;_ end of defun (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark doc) (setq point1 (getpoint "\nSpecify first extension line origin:")) (while (setq point2 (getpoint "\nSpecify second extension line origin:")) (command "_.dimaligned" point1 point2 pause) (setq point1 point2) ) ;_ end of while (vla-endundomark doc) (princ) ) ;_ end of defun (vl-load-com) Edited December 15, 2015 by PDuMont Edited per Tharwat's advice 1 Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 15, 2015 Share Posted December 15, 2015 (setq point1 nil) (setq point1 point2) Hi PDuMont, There is no need to set the variable point1 to nil before assigning it to another value . Quote Link to comment Share on other sites More sharing options...
PDuMont Posted December 15, 2015 Share Posted December 15, 2015 Hi Tharwat, Yeah, I was unsure of that... Thanks for the clarification. Quote Link to comment Share on other sites More sharing options...
hibba Posted December 16, 2015 Author Share Posted December 16, 2015 Here is my version of PDIM... It works for LWPOLYLINE(s) and have option for "INSIDE" - "OUTSIDE"... (defun c:pdim ( / ListClockwise-p ch plSet pLlst vLst oldOsn cAng cDis cPt ) (defun ListClockwise-p ( lst / z vlst ) (vl-catch-all-apply 'minusp (list (if (not (equal 0.0 (setq z (apply '+ (mapcar (function (lambda (u v) (- (* (car u) (cadr v)) (* (car v) (cadr u))) ) ) (setq vlst (mapcar (function (lambda (a b) (mapcar '- b a)) ) (mapcar (function (lambda (x) (car lst))) lst) (cdr (reverse (cons (car lst) (reverse lst)))) ) ) (cdr (reverse (cons (car vlst) (reverse vlst)))) ) ) ) 1e-6 ) ) z (progn (prompt "\n\nChecked vectors are colinear - unable to determine clockwise-p of list") nil ) ) ) ) ) (initget 1 "Outside Inside") (setq ch (getkword "\nChoose on which side to put dimensions [Outside/Inside] : ")) (princ "\n<<< Select LwPolyline(s) for dimensioning >>> ") (if (setq plSet (ssget '((0 . "LWPOLYLINE")))) (progn (setq pLlst (vl-remove-if 'listp (mapcar 'cadr(ssnamex plSet))) oldOsn (getvar "OSMODE") ); end setq (setvar "OSMODE" 0) (setvar "CMDECHO" 0) (command "_.undo" "_be") (foreach pl pLlst (setq vLst (mapcar '(lambda( x ) (trans x 0 1)) (mapcar 'cdr (vl-remove-if-not '(lambda( x ) (= 10 (car x))) (entget pl) ) ) ) ); end setq (if (equal (logand (cdr (assoc 70 (entget pl))) 1) 1) (setq vLst (append vLst (list (car vLst)))) ); end if (if (not (ListClockwise-p vLst)) (setq vLst (reverse vLst))) (while (< 1 (length vLst)) (setq cAng (angle (car vLst) (cadr vLst)) cDis (/ (distance (car vLst) (cadr vLst)) 2.0) ) ; (if (>= (caar vLst) (caadr vLst)) ; (setq cAng (- cAng pi)) ; ); end if (if (eq ch "Inside") (setq cPt (polar (polar (car vLst) cAng cDis) (- cAng (* 0.5 pi)) (* 2.5 (getvar "DIMTXT")))); end setq (setq cPt (polar (polar (car vLst) cAng cDis) (+ cAng (* 0.5 pi)) (* 2.5 (getvar "DIMTXT")))); end setq ); end if (command "_.dimaligned" (car vLst) (cadr vLst) cPt) (setq vLst (cdr vLst)) ); end while ); end foreach (command "_.undo" "_e") (setvar "OSMODE" oldOsn) (setvar "CMDECHO" 1) ); end progn ); end if (princ) ); end of c:pdim HTH, M.R. Thanks MR Marko, this is helpful for me... Quote Link to comment Share on other sites More sharing options...
hibba Posted December 16, 2015 Author Share Posted December 16, 2015 (edited) Hi hibba, See if this works for you. Use it just like the standard dimcontinue: ;; DimAlignedContinue ;; (defun c:DAC ( / *error* doc point1 point2 ) (defun *error* (msg) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) ) (princ (strcat "\nError: " msg)) ) (if doc (vla-endundomark doc) ) (princ) ) ;_ end of defun (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark doc) (setq point1 (getpoint "\nSpecify first extension line origin:")) (while (setq point2 (getpoint "\nSpecify second extension line origin:")) (command "_.dimaligned" point1 point2 pause) (setq point1 point2) ) ;_ end of while (vla-endundomark doc) (princ) ) ;_ end of defun (vl-load-com) Thanks so much Mr. PDuMont, this is exactly what i want... this is working fine for me Edited December 16, 2015 by hibba 1 Quote Link to comment Share on other sites More sharing options...
rashidsohail13 Posted December 16, 2015 Share Posted December 16, 2015 Thanks Great Work Now i work more better and Fast Again Thanks. Quote Link to comment Share on other sites More sharing options...
PDuMont Posted December 16, 2015 Share Posted December 16, 2015 Thanks so much Mr. PDuMont, this is exactly what i want... this is working fine for me You're very welcome. I've received great help, and have learned a lot here, so it's nice to give back. Quote Link to comment Share on other sites More sharing options...
