scattermaster Posted January 2, 2009 Author Share Posted January 2, 2009 I guess I could just delete the duplicated ones. Jim Quote Link to comment Share on other sites More sharing options...
scattermaster Posted January 2, 2009 Author Share Posted January 2, 2009 Nope, It won't let me delete. I guess it stays as is. Jim Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 2, 2009 Share Posted January 2, 2009 Sounds like you enjoy playing with fire. Careful you don't get burned. Quote Link to comment Share on other sites More sharing options...
scattermaster Posted January 2, 2009 Author Share Posted January 2, 2009 It's worth it from the point of view that you'll learn, once and for all, where one of the most important files in AutoCAD is located in case you ever need to actually find it. This is important if you are going to customize AutoCAD. Of course your right about that. The more I learn, the more I can help myself! Jim Quote Link to comment Share on other sites More sharing options...
scattermaster Posted January 2, 2009 Author Share Posted January 2, 2009 I use autocad LT on vista & thought would try to look.I did search & found lots of cui files in C:/Documents and Settings/[yourcomputernamehere]/Application Data/AutoDesk/AutoCAD LT 2008/R13/enu/support. & I laos found the vergine copy in the folder mentioned above. In Vista Business I don't seem to have "documents & settings" Jim Quote Link to comment Share on other sites More sharing options...
