argentatus Posted December 10, 2015 Posted December 10, 2015 I created a drawing containing a clipped xrefs on PC. : base drawing + xrefs(xclip and bind) Then uploaded to AutoCAD360. When I open this drawing(mobile), the clipping is ignored and full xrefs block is visible. AutoCAD360 doesn't support xclipped xrefs or did i something wrong? Quote
RobDraw Posted December 10, 2015 Posted December 10, 2015 The bound XREF block didn't get exploded, did it? Quote
argentatus Posted December 11, 2015 Author Posted December 11, 2015 The bound xref block didn't get exploded. should I explode that? Quote
RobDraw Posted December 11, 2015 Posted December 11, 2015 No, the clip (that you don't have) gets lost when you explode. That was a stab in the dark as I don't use A360 to test. You say it is gone when you open mobile. I assume that is some sort of app, not full AutoCAD. Maybe the app doesn't support XClip? Quote
