Grrr Posted December 8, 2015 Posted December 8, 2015 Hello, So I use this Lee Mac's lisp for counting att values, but the problem is that I have too many attributed blocks (for levels, labeling materials, labeling doortype, windowtype and so on..). The table created from my selectionset gets too big with 80% useless information, where I want to extract info from 1 or 2 blocks. My question is: Could someone modify it, to count those attributes of specified blocks? Example: 1.Select blocks to count their att values 2.Proceed with selectionset and filter only these selected blocks and count their attrib values Quote
Lee Mac Posted December 8, 2015 Posted December 8, 2015 As a quick modification, add the following line at line 70 of the code: (setq alist (vl-remove-if-not '(lambda ( x ) (member (car x) '([highlight]"A1" "A2"[/highlight]))) alist)) List the attribute tags you wish the program to count. Dipesh, I believe the OP is referring to my Count Attribute Values program. Quote
Grrr Posted December 8, 2015 Author Posted December 8, 2015 Well, thats not quite I was looking for, but it does the job: (setq alist (vl-remove-if-not '(lambda ( x ) (member (car x) '("П1" "П2" "П3" "П4" "П5" "П6" "П7" "П8" "П9" "П10" "П11" "П12" "A1" "A2" "A3" "A4" "A5" "A6" "A7"))) alist)) If I don't get *error* too long string on input. Tried: (setq att-string (getstring T "\nType attribute name to count: ")) (setq alist (vl-remove-if-not '(lambda ( x ) (member (car x) '("att-string"))) alist)) But It didn't work. Quote
