Insert block that have xref attached
I have a main drawing that have an xrefs attached, I have three other drawings with the same xrefs. How do I insert the blocks without detaching the xrefs?
EXAMPLE
Main.dwg [xrefs: 1flpln, 1light] (blocks: room_1, room_2, room_3)
Room_1.dwg [xrefs: 1flpln, 1light]
Room_2.dwg [xrefs: 1flpln, 1light]
Room_3.dwg [xrefs: 1flpln, 1light]
The problem is without detaching the xrefs in room 1,2, and 3; all the xrefs are re-attached even though ALL xrefs are overlayed.
EXAMPLE
Main.dwg [xrefs: 1flpln, 1light] (Blocks: room_1
room_2
room_3
[xrefs: 1flpln, 1light])
I'm sorry for the long post just trying to get the point across, blocks with xrefs attached brings multipule unwanted xrefs, need a way to fix without detaching ALL xrefs before hand... Thanks in advance.
I've never used XREFs within blocks. It just sounds like it would be wrought with problems. If I were you, I would change those blocks to be XREFs.
