Hi,
I search many forums but I can not find the solution.
I have many texts in my drawing with different angles. I try to add a new text object before these texts that contains ID number. What I want to do is these ID number texts have the same angle with old texts.
I use
NewAngle as Double
I can't assign Text angle value to "NewAngle" variable
Thanks for your help!
I found the solution. it's been very simple. Here is the answer;
dim angle as double
angle = Text_1.Rotation
Text_2.Rotate MidPoint, angle
Text_2.Update
