kclanton Posted March 9, 2007 Posted March 9, 2007 I would like to know if there's a way to send my part numbers (block attributes) to Excel and have them populate to a worksheet named the same as the drawing they came from. excel file = Myproject.xls drawing file names = Item 1.dwg, Item 2.dwg, Item 3.dwg excel sheet names = match the drawing file names Each drawing contains several blocks, each block with its part number stored as an attribute. I would like to be able to create each drawing by inserting blocks, then be able to click a button that sends all of the part numbers in Item 1.dwg to Myproject.xls and dumps onto sheet Item 1. I would then proceed to creating Item 2 and Item 3.dwg, and be able to click the "send to Excel" button, which would send to the same Myproject.xls Basically, what I would like to do is collect all part numbers from many drawing into one Main Project Excel file. It's been 10 years since I've worked with any lisp programming and I don't remember most of what I did know. - Now, it seems there are all sorts of programming options to use... My question is, can this be done at all? And, if so, what method would the experts recommend using. If it would be simplier to have all the drawings done and then open Excel and run some extraction code to pull the data in from each of the drawing at the end, that would be good too. Any help would be greatly appreciated. Quote
Spageddie Posted March 12, 2007 Posted March 12, 2007 hmm..this is one of those yes it should be possible.. From my perspective in VBA yes...not sure about LISP though. Quote
Kirk Mac Posted March 12, 2007 Posted March 12, 2007 This might get you started, is it something like what you're looking for? 'The following will cycle throught the Attributes, and put each 'block's attribut chart on a seperate worksheet, then you just save 'the workbook. You can put this in a sub routine, and call it when 'you need it, so you could have another loop elsewhere in your 'program that would cycle through your drawings and call this sub 'for each. For i = 0 To A2K4dwg.ModelSpace.Count - 1 'Check to see that the entity is a Block Reference If A2K4dwg.ModelSpace.Item(i).EntityType = acBlockReference Then If A2K4dwg.ModelSpace.Item(i).HasAttributes Then 'Store the attribute references in an array, extract 'the data, and put it into a cell Attr = A2K4dwg.ModelSpace.Item(i).GetAttributes For j = 0 To UBound(Attr) YourXLDoc.Worksheets(i).Range(Cells(j + 1, 1).Address).Value = Attr(j).TagString YourXLDoc.Range(Cells(j + 1, 2).Address).Value = Attr(j).TextString Next j End If End If Next i 'Then save your Worksheet (You can find that) See this thread on how to cycle through Documents, it's the For each Document in Documents" part. I haven't done any lisp, but I'm pretty sure it's not possible to access Excel with it, you'll have to use VB I think. See if that can get you started. Kirk Quote
VVA Posted March 13, 2007 Posted March 13, 2007 (vl-load-com) (defun mip-reg-get-path ()"HKEY_LOCAL_MACHINE\\Software\\MIP") (defun mip-reg-write (key value ) ;;;Ïèøåì â ïðîôèëü â ïêïêó ÌÈÏ (vl-registry-write (mip-reg-get-path) (VL-PRINC-TO-STRING key)(VL-PRINC-TO-STRING value))) (defun mip-reg-read ( key )(vl-registry-read (mip-reg-get-path) (VL-PRINC-TO-STRING key))) (defun mip-conv-to-str (dat)(if dat (vl-princ-to-string dat) "")) (defun get-all-atts (obj) (if (and obj (eq :vlax-true (vla-get-HasAttributes obj)) (vlax-property-available-p obj 'Hasattributes)) (vl-catch-all-apply (function (lambda() (mapcar (function (lambda (x) (cons (vla-get-TagString x) (vla-get-TextString x)))) (append (vlax-invoke obj 'Getattributes) (vlax-invoke obj 'Getconstantattributes) ))))))) ;|================== XLSF ======================================== * Arguments: punto_datos - The list of lists of data (LIST) ((Value1 Value2 ... VlalueN)(Value1 Value2 ... VlalueN)...) Each list of a kind (Value1 Value2... VlalueN) enters the name in a separate line in corresponding columns (Value1-A Value2-B and .ò.ä.) header - The list (LIST) headings or nil a kind (" Signature A " " Signature B "...) If header nil, is accepted ("X" "Y" "Z") Colhide - The list of alphabetic names of columns to hide or nil - to not hide ("A" "C" "D") - to hide columns A, C, D Name_list - The name of a new leaf of the active book or nil - is not present filename - xls file * Return: nil * Usage (xlsf '((1.1 1.2 1.3 1.4)(2.1 2.2 2.3 2.4)(3.1 3.2 3.3 3.4)) '("Col1" "Col2" "Col3" "Col4") '("B") "test" (getfiled "Excel Spreadsheet File" "" "XLS" ) |; (defun xlsf ( punto_datos header Colhide Name_list filename / *aplexcel* *books-colection* Currsep *excell-cells* *new-book* *sheet#1* *sheet-collection* col iz_listo row cell cols) (defun Letter (N / Res TMP)(setq Res "")(while (> N 0)(setq TMP (rem N 26) TMP (if (zerop TMP)(setq N (1- N) TMP 26) TMP) Res (strcat (chr (+ 64 TMP)) Res) N (/ N 26))) Res) (if (null Name_list)(setq Name_list "")) (setq *AplExcel* (vlax-get-or-create-object "Excel.Application")) (vlax-invoke-method (vlax-get-property *AplExcel* 'WorkBooks) 'Open fileName) (vla-put-visible *AplExcel* 1) (setq *Books-Colection* (vlax-get *AplExcel* "Workbooks")) (setq *New-Book* (vlax-get-property *AplExcel* "ActiveWorkbook")) (setq *Sheet-Collection* (vlax-get-property *New-Book* "Sheets")) (setq *Sheet#1* (vlax-invoke-method *Sheet-Collection* "Add")) (setq *excell-cells* (vlax-get-property *Sheet#1* "Cells")) (setq Name_list (if (= Name_list "") (vl-filename-base(getvar "DWGNAME")) (strcat (vl-filename-base(getvar "DWGNAME")) "&" Name_list)) col 0 cols nil) (vlax-for sh *Sheet-Collection* (setq cols (cons (strcase(vlax-get-property sh 'Name)) cols))) (setq row Name_list) (while (member (strcase row) cols)(setq row (strcat Name_list " (" (itoa(setq col (1+ col)))")"))) (setq Name_list row) (vlax-put-property *Sheet#1* 'Name Name_list) (setq Currsep (vlax-get-property *AplExcel* "UseSystemSeparators")) (vlax-put-property *AplExcel* "UseSystemSeparators" :vlax-false) (vlax-put-property *AplExcel* "DecimalSeparator" ".") (vlax-put-property *AplExcel* "ThousandsSeparator" " ") (vla-put-visible *AplExcel* :vlax-true)(setq row 1 col 1) (if (null header)(setq header '("X" "Y" "Z"))) (repeat (length header)(vlax-put-property *excell-cells* "Item" row col (vl-princ-to-string (nth (1- col) header)))(setq col (1+ col)))(setq row 2 col 1) (repeat (length punto_datos)(setq iz_listo (car punto_datos))(repeat (length iz_listo) (vlax-put-property *excell-cells* "Item" row col (vl-princ-to-string (car iz_listo))) (setq iz_listo (cdr iz_listo) col (1+ col)))(setq punto_datos (cdr punto_datos))(setq col 1 row (1+ row))) (setq col (1+(length header)) row (1+ row)) (setq cell (vlax-variant-value (vlax-invoke-method *Sheet#1* "Evaluate" (strcat "A1:" (letter col)(itoa row))))) (setq cols (vlax-get-property cell 'Columns)) (vlax-invoke-method cols 'Autofit) (vlax-release-object cols)(vlax-release-object cell) (foreach item ColHide (if (numberp item)(setq item (letter item))) (setq cell (vlax-variant-value (vlax-invoke-method *Sheet#1* "Evaluate" (strcat item "1:" item "1")))) (setq cols (vlax-get-property cell 'Columns)) (vlax-put-property cols 'hidden 1) (vlax-release-object cols)(vlax-release-object cell)) (vlax-put-property *AplExcel* "UseSystemSeparators" Currsep) (mapcar 'vlax-release-object (list *excell-cells* *Sheet#1* *Sheet-Collection* *New-Book* *Books-Colection* *AplExcel*))(setq *AplExcel* nil)(gc)(gc)(princ)) (defun C:SETXLSFILE ( / fn1) (setq fn1 (getfiled "Excel Spreadsheet File" (if oldFileName oldFileName "") "XLS" ) (mip-reg-write "LASTXLSDIR" (vl-filename-directory fn1)) (mip-reg-write "LASTXLSFILE" (strcat (vl-filename-base fn1)(vl-filename-extension fn1))) (princ)) (defun C:ATTEXP2XL ( / fn1 filename blk pat head ss datalist att_list) (setq fn1 (strcat (mip-conv-to-str(mip-reg-read "LASTXLSDIR")) "\\" (mip-conv-to-str(mip-reg-read "LASTXLSFILE")))) (if (vl-file-systime fn1) (setq fileName fn1) (setq fileName (getfiled "Excel Spreadsheet File" (if oldFileName oldFileName "") "XLS" ) ) (if (vl-file-systime (vl-princ-to-string fileName)) (progn (setq oldFileName fileName) (princ "\nChoose a block") (while (not(setq ss (ssget "_+.:S:E" '((0 . "INSERT")(66 . 1))))) (princ "\nWrong... Choose a block with attributes")) (setq blk (ssname ss 0) ss nil) (setq pat (vl-remove-if-not '(lambda(x)(member (car x) '(0 2 410)))(entget blk))) (setq head nil datalist nil) (if (setq ss (ssget "_X" pat)) (progn (foreach item (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (setq att_list (get-all-atts item)) (if (null head)(setq head (mapcar 'car att_list))) (setq datalist (append datalist (list (mapcar 'cdr att_list)))) ) (xlsf datalist head nil nil fileName) ) ) ) (alert (strcat "Cann't open\n" filename "\nMay be open or missing")) ) (princ) ) Two commands SETXLSFILE - remembers a name of a file ATTEXP2XL - exports attributes of the block to a file Quote
firsrate_caduser Posted March 21, 2007 Posted March 21, 2007 Hi guys how do you make to work this code in autocad? thanks for your input... Quote
VVA Posted March 22, 2007 Posted March 22, 2007 Hi guys how do you make to work this code in autocad? thanks for your input... http://www.cadtutor.net/forum/showthread.php?t=1390 Quote
VVA Posted March 22, 2007 Posted March 22, 2007 Sorry for my for bad English. I would act on another. Following commands send the information in active document Excell, if it is not present it is created. It is enough to open the necessary file before a call of a command and to send it the necessary information. Next two commnads: ATTEXP2XL - exports attributes of the block to active document Excell to specific sheet AREAS - Send the Layer, area, length, color, a hyperlink of selected polyline in corresponding columns Excel. (vl-load-com) (defun mip-conv-to-str (dat)(if dat (vl-princ-to-string dat) "")) (defun get-all-atts (obj) (if (and obj (eq :vlax-true (vla-get-HasAttributes obj)) (vlax-property-available-p obj 'Hasattributes)) (vl-catch-all-apply (function (lambda() (mapcar (function (lambda (x) (cons (vla-get-TagString x) (vla-get-TextString x)))) (append (vlax-invoke obj 'Getattributes) (vlax-invoke obj 'Getconstantattributes) ))))))) ;|================== XLS ======================================== * Purpose: Export of the list of data punto_datos in Excell * It is exported to a new leaf of the current book. If the book is not present, it is created * Arguments: punto_datos - The list of lists of data (LIST) ((Value1 Value2 ... VlalueN)(Value1 Value2 ... VlalueN)...) Each list of a kind (Value1 Value2... VlalueN) enters the name in a separate line in corresponding columns (Value1-A Value2-B and .ò.ä.) header - The list (LIST) headings or nil a kind (" Signature A " " Signature B "...) If header nil, is accepted ("X" "Y" "Z") Colhide - The list of alphabetic names of columns to hide or nil - to not hide ("A" "C" "D") - to hide columns A, C, D Name_list - The name of a new leaf of the active book or nil - is not present * Return: nil * Usage (xls '((1.1 1.2 1.3 1.4)(2.1 2.2 2.3 2.4)(3.1 3.2 3.3 3.4)) '("Col1" "Col2" "Col3" "Col4") '("B") "test") |; (vl-load-com) (defun xls ( punto_datos header Colhide Name_list / *aplexcel* *books-colection* Currsep *excell-cells* *new-book* *sheet#1* *sheet-collection* col iz_listo row cell cols) (defun Letter (N / Res TMP)(setq Res "")(while (> N 0)(setq TMP (rem N 26) TMP (if (zerop TMP)(setq N (1- N) TMP 26) TMP) Res (strcat (chr (+ 64 TMP)) Res) N (/ N 26))) Res) (if (null Name_list)(setq Name_list "")) (setq *AplExcel* (vlax-get-or-create-object "Excel.Application")) (if (setq *New-Book* (vlax-get-property *AplExcel* "ActiveWorkbook")) (setq *Books-Colection* (vlax-get-property *AplExcel* "Workbooks") *Sheet-Collection* (vlax-get-property *New-Book* "Sheets") *Sheet#1* (vlax-invoke-method *Sheet-Collection* "Add")) (setq *Books-Colection* (vlax-get-property *AplExcel* "Workbooks") *New-Book* (vlax-invoke-method *Books-Colection* "Add") *Sheet-Collection* (vlax-get-property *New-Book* "Sheets") *Sheet#1* (vlax-get-property *Sheet-Collection* "Item" 1))) (setq *excell-cells* (vlax-get-property *Sheet#1* "Cells")) (setq Name_list (if (= Name_list "") (vl-filename-base(getvar "DWGNAME")) (strcat (vl-filename-base(getvar "DWGNAME")) "&" Name_list)) col 0 cols nil) (vlax-for sh *Sheet-Collection* (setq cols (cons (strcase(vlax-get-property sh 'Name)) cols))) (setq row Name_list) (while (member (strcase row) cols)(setq row (strcat Name_list " (" (itoa(setq col (1+ col)))")"))) (setq Name_list row) (vlax-put-property *Sheet#1* 'Name Name_list) (setq Currsep (vlax-get-property *AplExcel* "UseSystemSeparators")) (vlax-put-property *AplExcel* "UseSystemSeparators" :vlax-false) ;_êå èñïîëüçîâêòü ñèñòåìêûå óñòêêîâêè (vlax-put-property *AplExcel* "DecimalSeparator" ".") ;_ðêçäåëèòåëü äðîáêîé è öåëîé ÷êñòè (vlax-put-property *AplExcel* "ThousandsSeparator" " ") ;_ðêçäåëèòåëü òûñÿ÷åé (vla-put-visible *AplExcel* :vlax-true)(setq row 1 col 1) (if (null header)(setq header '("X" "Y" "Z"))) (repeat (length header)(vlax-put-property *excell-cells* "Item" row col (vl-princ-to-string (nth (1- col) header)))(setq col (1+ col)))(setq row 2 col 1) (repeat (length punto_datos)(setq iz_listo (car punto_datos))(repeat (length iz_listo) (vlax-put-property *excell-cells* "Item" row col (vl-princ-to-string (car iz_listo))) (setq iz_listo (cdr iz_listo) col (1+ col)))(setq punto_datos (cdr punto_datos))(setq col 1 row (1+ row))) (setq col (1+(length header)) row (1+ row)) (setq cell (vlax-variant-value (vlax-invoke-method *Sheet#1* "Evaluate" (strcat "A1:" (letter col)(itoa row))))) ;_ end of setq (setq cols (vlax-get-property cell 'Columns)) (vlax-invoke-method cols 'Autofit) (vlax-release-object cols)(vlax-release-object cell) (foreach item ColHide (if (numberp item)(setq item (letter item))) (setq cell (vlax-variant-value (vlax-invoke-method *Sheet#1* "Evaluate" (strcat item "1:" item "1")))) (setq cols (vlax-get-property cell 'Columns)) (vlax-put-property cols 'hidden 1) (vlax-release-object cols)(vlax-release-object cell)) (vlax-put-property *AplExcel* "UseSystemSeparators" Currsep) (mapcar 'vlax-release-object (list *excell-cells* *Sheet#1* *Sheet-Collection* *New-Book* *Books-Colection* *AplExcel*))(setq *AplExcel* nil)(gc)(gc)(princ)) (defun C:ATTEXP2XL ( / blk pat head ss datalist att_list) (princ "\nChoose a block") (while (not(setq ss (ssget "_+.:S:E" '((0 . "INSERT")(66 . 1))))) (princ "\nWrong... Choose a block with attributes")) (setq blk (ssname ss 0) ss nil) (setq pat (vl-remove-if-not '(lambda(x)(member (car x) '(0 2 410)))(entget blk))) (setq head nil datalist nil) (if (setq ss (ssget "_X" pat)) (progn (foreach item (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (setq att_list (get-all-atts item)) (if (null head)(setq head (mapcar 'car att_list))) (setq datalist (append datalist (list (mapcar 'cdr att_list)))) ) (xls datalist head nil nil) ) ) (princ) ) ;|=============== Comand AREAS ================================================ Send the Layer, the area, length, color, a hyperlink in corresponding columns Excel. See also _HYPERLINKOPTIONS |; (defun c:AREAS (/ selset *error* retLst lst i UrlDes are) (defun *error* (msg)(princ msg)(princ)) ;_ end of defun (vl-load-com) (if (setq selset (ssget '((0 . "*POLYLINE"))))(progn (setq i 1) (foreach item (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex selset)))) (if(not (zerop(vla-get-Count (vla-get-Hyperlinks item)))) (VL-CATCH-ALL-APPLY '(lambda()(setq UrlDes(vla-get-URLDescription(vla-item (vla-get-Hyperlinks item) 0))))) (setq UrlDes "")) (setq lst (list (strcat "'" (vla-get-layer item)) ;|Layer"|; (rtos(setq are(vla-get-area item)) 2 12) ;|Area|; (rtos(vla-get-Length item) 2 12) ;|Length|; (vla-get-color item) ;|Color|; (if (= UrlDes "") "" (strcat "'" UrlDes)) ;|Hyperlink|; )) (setq retLst (append retLst (list lst))));_foreach (xls retlst '("Layer" "Area" "Length" "Color" "Hyperlink") nil "from AREAS"))) (princ)) Quote
firsrate_caduser Posted March 22, 2007 Posted March 22, 2007 thanks VVA I though for vba was a different procedure. Anyways your CODE works just fine...thank you very much!! My life would be much easier now. I had to deal with a of attributes extraction. one more question if you modified the extraction in excel it would make that change to the drawing? thanks for your help!! Quote
VVA Posted March 23, 2007 Posted March 23, 2007 Good sites on work with Excell http://www.atablex.com/ http://www.jefferypsanders.com/autolisp.html Quote
Harun KILIC Posted April 3, 2007 Posted April 3, 2007 Another code from new member:P; You just pick a block object with attr. from Acad; this code runs Excel App. and make an attributes list of all related blocks, including header info. Even if the block is on Model or Layout Tab Public Sub PickBlockToExtactAttrToExcel() Dim getAcObj As AcadObject Dim basePnt As Variant On Error Resume Next RETRY: ThisDrawing.Utility.GetEntity getAcObj, basePnt, "Pick a block to extact attributes to Excel.." If Err <> 0 Then Err.Clear Exit Sub Else If getAcObj.ObjectName <> "AcDbBlockReference" Then GoTo RETRY End If Dim Array1 As Variant Dim RowNum As Long RowNum = 1 Dim elem As AcadEntity Dim aCount As Long Dim Header As Boolean For Each elem In ThisDrawing.ActiveLayout.Block If elem.EntityName = "AcDbBlockReference" Then If elem.Name = getAcObj.Name Then If elem.HasAttributes Then Array1 = elem.GetAttributes If Header = False Then Dim anExcelApp As Object Set anExcelApp = GetObject(, "Excel.Application") If Err.Number Then Err.Clear Set anExcelApp = CreateObject("Excel.Application") If Err <> 0 Then Err.Clear MsgBox "Excel is not installed" End End If End If anExcelApp.Visible = True anExcelApp.WindowState = 3 Dim anExcelActiveWorkBook As Object Set anExcelActiveWorkBook = anExcelApp.Workbooks.Add anExcelActiveWorkBook.Activate Dim anExcelActiveSheet As Object Set anExcelActiveSheet = anExcelActiveWorkBook.ActiveSheet For aCount = LBound(Array1) To UBound(Array1) If Array1(aCount).EntityName = "AcDbAttribute" Then anExcelActiveSheet.Cells(RowNum, aCount + 1) = Array1(aCount).TagString End If Next aCount RowNum = 2 Header = True End If For aCount = LBound(Array1) To UBound(Array1) anExcelActiveSheet.Cells(RowNum, aCount + 1) = Array1(aCount).TextString anExcelActiveSheet.Columns(aCount + 1).EntireColumn.AutoFit Next aCount RowNum = RowNum + 1 End If End If End If Next elem ''''' End Sub One of the members asked for; if he can export a special number format like "001" in an attribute text, will be the same in Excel sheet; Replace these lines of the code For aCount = LBound(Array1) To UBound(Array1) anExcelActiveSheet.Cells(RowNum, aCount + 1) = Array1(aCount).TextString anExcelActiveSheet.Columns(aCount + 1).EntireColumn.AutoFit Next aCount as in following. Included code line will format the cells as text. For aCount = LBound(Array1) To UBound(Array1) anExcelActiveSheet.Cells(RowNum, aCount + 1).NumberFormat = "@" anExcelActiveSheet.Cells(RowNum, aCount + 1) = Array1(aCount).TextString anExcelActiveSheet.Columns(aCount + 1).EntireColumn.AutoFit Next aCount Long Live ActiveX! Quote
plecs Posted May 1, 2014 Posted May 1, 2014 hy help my i want to export all attrib from dwg you have to change everything now export to export a single attr but I want to select all and export them can you help me with this please Quote
Spaj Posted May 1, 2014 Posted May 1, 2014 Hi Have a look at LeeMac's excellent collection of LISP routines. This particular one may be of interest... http://www.lee-mac.com/macatt.html Quote
