masterfal Posted August 12, 2016 Posted August 12, 2016 is it possible to add something to this code so that it specifies the number of wipeouts removed? (vl-load-com) (defun c:Test (/ b o) ;;--- Tharwat 26.June.2013 ---;; (or doc (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) ) (vlax-for b (vla-get-blocks doc ) (if (and (eq :vlax-false (vla-get-isLayout b)) (eq :vlax-false (vla-get-isXref b)) ) (vlax-for o b (if (eq "AcDbWipeout" (vla-get-objectname o)) (vl-catch-all-apply 'vla-delete (list o)) ) ) ) ) (if (setq ss (ssget "_X" '((0 . "WIPEOUT")(410 . "Model")))) (command "_.erase" ss "") ) (vla-regen doc acAllViewports) (princ) ) Quote
kpblc Posted August 12, 2016 Posted August 12, 2016 Try this. I added proceeding layers and counters for successfully and error erasing wipeouts remove-wipeout.LSP Quote
masterfal Posted August 12, 2016 Posted August 12, 2016 Try this. I added proceeding layers and counters for successfully and error erasing wipeouts cool thanks for having a look. after testing this its returning: "Too many actual parameters" Any ideas why thats happening? Quote
masterfal Posted August 12, 2016 Posted August 12, 2016 Ah, sorry. New version: almost perfect... just need it to also include wipeouts inside of blocks. the original code i posted included removing wipeouts inside of blocks (thats why i like this one so much), it just doesn't return how many Quote
kpblc Posted August 12, 2016 Posted August 12, 2016 My code include wipeouts in ALL blocks (exclude external references) and ALL layouts. Check it! Quote
Tharwat Posted August 12, 2016 Posted August 12, 2016 (edited) is it possible to add something to this code so that it specifies the number of wipeouts removed? Try this: (defun c:Test (/ num doc ss i) ;;--- Tharwat 12.Aug.2016 ---;; (setq num 0 doc (vla-get-ActiveDocument (vlax-get-acad-object)) ) (vlax-for b (vla-get-blocks doc ) (if (and (eq :vlax-false (vla-get-isLayout b)) (eq :vlax-false (vla-get-isXref b)) ) (vlax-for o b (if (and (eq "AcDbWipeout" (vla-get-objectname o)) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-delete (list o)))) ) (setq num (1+ num)) ) ) ) ) (if (setq ss (ssget "_X" '((0 . "WIPEOUT") (410 . "Model")))) (repeat (setq i (sslength ss)) (if (entdel (ssname ss (setq i (1- i)))) (setq num (1+ num)) ) ) ) (vla-regen doc acAllViewports) (if (< 0 num) (princ (strcat "\nNumber of deleted Wipeout(s) is: [" (itoa num) "]" ) ) (princ "\nNo Wipeouts found in this drawing !") ) (princ) )(vl-load-com) Edited August 16, 2016 by Tharwat Quote
masterfal Posted August 12, 2016 Posted August 12, 2016 kpblc, is there any way your code could have changed some of my settings because i'm getting the strangest things happening. alot of my lisp routines don't seem to work properly anymore (some commands i need to type twice as the first time it says its an unknown command and other commands just don't work at all - after working fine for years) and with blocks on my drawing when i double click to edit them the "edit block definition" dialog box appears and to edit it i have to pick the block from the list... so confused. if it wasn't your code would you have any other idea what could be causing that to happen? i can't work like this.. Quote
kpblc Posted August 12, 2016 Posted August 12, 2016 My code don't change any commands. As you can see, code used only ActiveX-technology, no commands. Could you do some things, please? 1. Attach any dwg with wipeouts inside blocks. I changed code to update block definitions, but i'm not sure it's enough. 2. What kind of commands you have to type twice? 3. What you code doesn't work? 4. Version of AutoCAD is... And ServicePacks and hotfixes are installed or not? Once upon a time i wrote code like this (as i remember, hatches and wipeouts should be erased) - and noone reports me any problem. P.S. code: (vl-load-com) (defun c:remove-wipeout2 (/ adoc layers count err) (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object)))) (vlax-for item (vla-get-layers adoc) (if (not (wcmatch (vla-get-name item) "*|*")) (setq layers (cons (append (list item) (mapcar (function (lambda (prop / tmp) (setq tmp (vlax-get-property item prop)) (vl-catch-all-apply (function (lambda () (vlax-put-property item prop :vlax-false)))) (cons prop tmp) ) ;_ end of lambda ) ;_ end of function '("freeze" "lock") ) ;_ end of mapcar ) ;_ end of append layers ) ;_ end of cons ) ;_ end of setq ) ;_ end of if ) ;_ end of vlax-for (setq count 0 err 0 ) ;_ end of setq (vlax-for blk_def (vla-get-blocks adoc) (if (equal (vla-get-isxref blk_def) :vlax-false) (vlax-for ent blk_def (if (wcmatch (strcase (vla-get-objectname ent)) "*WIPEOUT*") (if (vl-catch-all-error-p (vl-catch-all-apply (function (lambda () (vla-erase ent))))) (setq err (1+ err)) (setq count (1+ count)) ) ;_ end of if ) ;_ end of if ) ;_ end of vlax-for ) ;_ end of if ;;; Attach string to update block definition (vl-catch-all-apply (function (lambda () (vla-update blk_def)))) ) ;_ end of vlax-for (foreach item layers (foreach prop (cdr item) (vl-catch-all-apply (function (lambda () (vlax-put-property (car item) (car prop) (cdr prop))))) ) ;_ end of foreach ) ;_ end of foreach ;;; Attach string to regenerate current document (vla-regen adoc acallviewports) (princ (strcat "\nErased wipeout : " (itoa count) "\nError erasing : " (itoa err))) (vla-endundomark adoc) (princ) ) ;_ end of defun Quote
masterfal Posted August 12, 2016 Posted August 12, 2016 my bad.. in regards to removing the wipeouts from blocks, i realised after that i needed to regen the drawing to see the wipeouts removed from blocks. so thats all good. sorry for implying it didn't work properly! basically majority of my custom commands either don't work or need to be input twice and even noticed "c" for 'copy' now does 'copy multiple'! where it got that from i have no idea. i've always had copy multiple as 'cm'. i even tried removing the reference to the custom lsp file i use (so as to return it to default settings/commands) which fixed the copy command it still did that weird thing where i can't edit blocks properly. i don't understand what happened or how to fix it i'm using autocad 2011.. Quote
masterfal Posted August 15, 2016 Posted August 15, 2016 copymode was set to 0. changed to 1. still not working properly. i'm thinking i may need to reinstall Quote
masterfal Posted August 15, 2016 Posted August 15, 2016 also just noticed when i try to edit any text it doesn't go into it straight away. it asks me which annotation i want to edit.. Quote
Tharwat Posted August 15, 2016 Posted August 15, 2016 is it possible to add something to this code so that it specifies the number of wipeouts removed? Did you try the last mods of my program that I did for you? Quote
masterfal Posted August 15, 2016 Posted August 15, 2016 yeh i just tried it then. it seems to be one of the commands i need to put in twice to work.. the first time i run it it says "test argument is not a vl-catch-all-apply error: nil" then if i try do it again it works.. this is doing my head in. can't work out why its doing this ps - it only seems to count the number of wipeouts removed which aren't in blocks. (when i tested i had one wipeout outside block and one inside, it removed them both but said only 1 deleted) Quote
Tharwat Posted August 15, 2016 Posted August 15, 2016 Sorry there was an extra function that is not needed, I modified it again - try it from HERE Quote
masterfal Posted August 15, 2016 Posted August 15, 2016 works perfect.. no need to regen to see wipeouts removed from blocks either, which is cool nice work Quote
Tharwat Posted August 15, 2016 Posted August 15, 2016 works perfect.. no need to regen to see wipeouts removed from blocks either, which is coolnice work Excellent. Quote
masterfal Posted August 16, 2016 Posted August 16, 2016 Hey Tharwat, One last thing to 'perfect' this code would be if it could return 0 if there are none removed. Not sure if that is an easy thing to add in or not.. At the moment when you try to use it and there are no wipeouts, it doesn't say anything so sometimes not sure if its actually run properly or not. Quote
