HackRaatz Posted December 29, 2008 Share Posted December 29, 2008 Hi there! I'm new to this forum. Is there a Pdf to dwg converter that is an open-source or General Public Lisence (GPL)? Any input would be much appreciated. Quote Link to comment Share on other sites More sharing options...
Dipali Posted December 29, 2008 Share Posted December 29, 2008 have alook at this http://www.cadtutor.net/forum/showthread.php?t=30696 Quote Link to comment Share on other sites More sharing options...
Tankman Posted December 29, 2008 Share Posted December 29, 2008 Hi there! I'm new to this forum. Is there a Pdf to dwg converter that is an open-source or General Public Lisence (GPL)? Any input would be much appreciated. Try pfd2cad, trial program. www.pdf2cad.com For the few times I want or need to convert *.pdf to *.dwg it does the job. I usually have to fix a lot of junque but, the program gets me started. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 29, 2008 Share Posted December 29, 2008 My one experience using this type of conversion program resulted in a drawing largely comprised of a multitude of small line segments. This made the new "drawing" much, much larger in file size and difficult to work with. Quote Link to comment Share on other sites More sharing options...
Tankman Posted December 29, 2008 Share Posted December 29, 2008 My one experience using this type of conversion program resulted in a drawing largely comprised of a multitude of small line segments. This made the new "drawing" much, much larger in file size and difficult to work with. Seems as a circle is 360 parts. I clean up what I want, drawing i.e.: a new circle. Most convert to a lot of "junque" but, enough to get started. And, as always PURGE. Quote Link to comment Share on other sites More sharing options...
Guest Xenophon Posted December 30, 2008 Share Posted December 30, 2008 McNeel makes a program that you can get a demo off that will read vectors out of AI and PDF files and save as DWG Quote Link to comment Share on other sites More sharing options...
cablegadson Posted December 30, 2008 Share Posted December 30, 2008 There are many free pdf to dwg converters all over the internet,I am using Autodwg pdf to dwg converter,you can free download and try to use this application. Quote Link to comment Share on other sites More sharing options...
Tankman Posted December 30, 2008 Share Posted December 30, 2008 There are many free pdf to dwg converters all over the internet,I am using Autodwg pdf to dwg converter,you can free download and try to use this application. Might you have a link to the download? Quote Link to comment Share on other sites More sharing options...
cablegadson Posted December 31, 2008 Share Posted December 31, 2008 Might you have a link to the download? You may google Autodwg pdf to dwg converter. Quote Link to comment Share on other sites More sharing options...
Cadfisch Posted January 5, 2009 Share Posted January 5, 2009 a program that works as good as the AdobePro is the free "pdf creator". Unfortunately I'm not supposed to post weblinks here but you'll find it easily regards Cadfisch Quote Link to comment Share on other sites More sharing options...
fuccaro Posted January 5, 2009 Share Posted January 5, 2009 Cadfish PdfCreator will plot your drawing in PDF format. Our friend HackRaatz asked for a way to convert it back from PDF into DWG. Quote Link to comment Share on other sites More sharing options...
