djx084 Posted November 15, 2015 Posted November 15, 2015 Intel® Core i5-4460 Box (3.20GHz, 4C/4T, FSB 1600MHz, 84W, 22nm, 6MB cache, VGA HD 4600, socket 1150) B85M-D3V /s1150, Intel® B85 Express Chipset, 2xDDR3, PCI Express x16, 2xPCI Express x1, 1 x PCI, D-SUB, DVI, GLan, Parallel port/ 8GB 1600MHz DDR3 JR 240pin B SSD 120GB Hyper X FURY Series (SATA III 6GB/s, Read 500Mbps, Write 500Mbps, 7mm, 2.5") INTEL HD 4600 ?????????????????????????????????[emoji1] Quote
Cad64 Posted November 15, 2015 Posted November 15, 2015 What version of Windows are you running, and is it 32 bit or 64 bit? What sort of work will you be doing? 2D drafting or 3D modeling and rendering? Have you seen this: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/System-requirements-for-AutoCAD-2014.html Quote
djx084 Posted November 16, 2015 Author Posted November 16, 2015 Windows 7 64bit, becouse 8gb ram... 2D in 90% ,and 10% for Gavran civil modeller> http://www.gcm-gavran.com/gavran-gcm-preview.htm Quote
Cad64 Posted November 16, 2015 Posted November 16, 2015 It should be fine for 2D Autocad, but I don't know anything about Gavran Civil modeller though. You might run into problems with only 8gb RAM. Quote
djx084 Posted November 25, 2015 Author Posted November 25, 2015 I instal cad2014 and nave problems with 3d orbit and cube view, when change view -autocad crash and close..... :-( Quote
ReMark Posted November 25, 2015 Posted November 25, 2015 Most likely due to the graphics chip that you have installed. I would recommend a dedicated graphics card. However, maybe this will help...http://www.intel.com/support/graphics/sb/CS-030506.htm BTW...how did you manage to get a hold of AutoCAD 2014? The latest version is AutoCAD 2016. Quote
djx084 Posted November 25, 2015 Author Posted November 25, 2015 I have installation of the above, the best we showed a version of hitherto Quote
ReMark Posted November 25, 2015 Posted November 25, 2015 I know you have the software my question is where did you get it from? As for the rest of your response it makes no sense. Want to try again? Quote
djx084 Posted November 25, 2015 Author Posted November 25, 2015 (edited) ............... Edited December 8, 2015 by djx084 Quote
djx084 Posted November 25, 2015 Author Posted November 25, 2015 2014 is best version for me... i dont try 2015 and 2016,but older version..2014 is best:-) Quote
ReMark Posted November 25, 2015 Posted November 25, 2015 Sorry, but I gave you all the help I am going to. Why? Because you are using illegal software while the rest of us, or the companies we work for, had to spend good money to get the same software. Quote
djx084 Posted November 25, 2015 Author Posted November 25, 2015 (edited) Yeeees..... Edited November 25, 2015 by djx084 Quote
ReMark Posted November 25, 2015 Posted November 25, 2015 That's not my problem. Anyway, I told you what I think the problem is AND I gave you a link to a possible fix. If the fix doesn't work then you'll have to swap out your graphics chip for a dedicated graphics card. Quote
