Squirltech Posted November 11, 2015 Posted November 11, 2015 I need some assistance here... I have a surface that was created in Acad 09, Land Desktop (attached file) but there are no .xml files and the original drawing can't be located. The person who did the original drawing, no longer works here (of course). Anyway, long story longer, I would like to create a surface from the linework provided, in Civil 2015 format, but I've tried all I know and I'm coming up empty handed. Any help would be greatly appreciated! Thanks in advance. T BLOCK-Surface07.dwgFetching info... Quote
BIGAL Posted November 12, 2015 Posted November 12, 2015 Took longer to download than to make Explode all plines, Add surface, create surface from lines. Only BUT! its not as accurate as original model as its converting contour lines to a surface but will be close. Quote
Squirltech Posted November 12, 2015 Author Posted November 12, 2015 In the original drawing, the lines are exploded. Turns out though, it wasn't needed for this project. I had created another surface from a previous Civil3d file, same project, different scope and that's what we ended up using. Thanks for the reply though. T Quote
