Hello,
I'm using a function to quickly divide a line. The divisions are rounded to a chosen distance.
(defun inzetpunten (/ obj num div objg)
   (while (not obj)
       (setq obj(entsel))
       (if obj (progn
           (setq objg (entget (car obj)))
           (setq num (/ (distance (cdr (assoc 10 objg)) (cdr (assoc 11 objg))) 400)) ; target distance = 400
           (if (< 0.5 (- num (fix num))) (setq div (1+ (fix num))) (setq div (fix num)))
           (if (> 2 div) (setq div 2))
           (command "divide" obj div)
       ) (princ "\nNothing was selected, Please select a line!"))
Now this works great. But I have a drawing with the same length lines, only one divides into 6 and the other divides into 7 parts.
I got a vlax dump of the 2 lines:
Select object: ; IAcadLine: AutoCAD Line Interface
; Property values:
;   Angle (RO) = 3.14159
;   Application (RO) = #<VLA-OBJECT IAcadApplication 000000013fd89110>
[color=red];   Delta (RO) = (-3000.0 9.09495e-013 0.0)[/color]
;   Document (RO) = #<VLA-OBJECT IAcadDocument 000000002f573368>
;   EndPoint = (-14065.0 5567.73 0.0)
;   EntityTransparency = "ByLayer"
;   Handle (RO) = "DB11"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0000000037a10f78>
;   Layer = "HULPLIJN"
;   Length (RO) = 3000.0
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Material = "ByLayer"
;   Normal = (0.0 0.0 1.0)
;   ObjectID (RO) = 44
;   ObjectName (RO) = "AcDbLine"
;   OwnerID (RO) = 43
;   PlotStyleName = "ByLayer"
;   StartPoint = (-11065.0 5567.73 0.0)
;   Thickness = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 0000000037a13370>
;   Visible = -1
T
; Property values:
[color=red];   Delta (RO) = (-3000.0 0.0 0.0)[/color]
;   EndPoint = (-14065.0 5685.33 0.0)
;   Handle (RO) = "DB3C"
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0000000037a13078>
;   Lineweight = -1
;   ObjectID (RO) = 42
;   OwnerID (RO) = 43
;   StartPoint = (-11065.0 5685.33 0.0)
;   Thickness = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 0000000037f29450>
;   Visible = -1
T
The only difference seems to be the delta, how can I work around this bug in my lisp? Thanks in advance!
Change:
to:
(setq div (atoi (rtos num 2 0)))
That is a much better way of rounding, thanks!
I love your website by the way, it has been really helpful learning autolisp.
