Jakub Posted November 10, 2015 Posted November 10, 2015 Hi, I've got a problem with txtexp command. After using this function text (*.shx) changes place on screen. For example I have some text inside my screen and when I use this command text moves on the right-corner (changing coordinates XY). How to stop this and maintain an original location? Thanks in advance , Jacob Quote
Cad64 Posted November 11, 2015 Posted November 11, 2015 What font are you using? Mtext or Dtext? I can't replicate the problem. Maybe you should post your file here for us to take a look at. Quote
Jakub Posted November 13, 2015 Author Posted November 13, 2015 Cad64 said: What font are you using?Mtext or Dtext? I can't replicate the problem. Maybe you should post your file here for us to take a look at. So It looks like this: Before using 'txtexp': And after I got exploded text in different place: How to maintain this text in the same place (original)? Quote
ReMark Posted November 13, 2015 Posted November 13, 2015 Is this plain text or multiline text? Is the text annotative? What font are you using? Quote
Jakub Posted November 13, 2015 Author Posted November 13, 2015 ReMark said: Is this plain text or multiline text? Is the text annotative? What font are you using? The text is marked as Standard, font: txt.shx and it is multiline text. Quote
ReMark Posted November 13, 2015 Posted November 13, 2015 That should be easy to test then. In my quick and simple test the multiline text I exploded remained in the exact same position. I too was unable to duplicate what you experienced using this font. However, I do believe you as I have had the same thing happen on rare occasions using other fonts. Quote
Jakub Posted November 13, 2015 Author Posted November 13, 2015 I noticed that always when I use this command my text is changing place exact on the right-corner of my screen and It is rescaled (text is much smaller than its original). Is it coused by text style I'm using? Quote
RobDraw Posted November 13, 2015 Posted November 13, 2015 It happens when exploding text with annotative scaling. Turn annotative off before exploding. Quote
BIGAL Posted November 14, 2015 Posted November 14, 2015 MY $0.05 have a look at TEXT TO GEOMETRY.lsp a very sophisticated product for exploding text. http://www.cadtutor.net/forum/showthread.php?90737-Text-To-Geometry-2015-Testing Quote
