Subiran Posted November 10, 2015 Posted November 10, 2015 Hi. I'm a beginner in CAD, I'm going to ask how to draft a lot using the coordinates(latitude and longitude) from google earth. Example: Point A. Latitude: 11 Degree 18'2.22"N Longitude: 124 Degree 57'46.89"E Please check my attachment picture. Quote
ReMark Posted November 10, 2015 Posted November 10, 2015 (edited) Please refrain from starting multiple threads in multiple forums asking the exact same question. It just leads to confusion. Thank you. In my opinion you would be better off using either Map 3D or Civil 3D if you are going to be entering your data as latitude and longitude. If you insist on doing this in plain AutoCAD I think you would have to convert from Degrees-Minutes-Seconds to Decimal Degrees. You can probably find a free conversion calculator online. I believe western and southern coordinates would have to be entered with a minus sign in front of them. Find a free converter here. https://www.fcc.gov/encyclopedia/degrees-minutes-seconds-tofrom-decimal-degrees Edited November 10, 2015 by ReMark Quote
tombu Posted November 10, 2015 Posted November 10, 2015 Like ReMark said you need Map, but these sites may help convert those coordinates to something useful: http://www.earthpoint.us/StatePlane.aspx & http://www.ngs.noaa.gov/TOOLS/ Quote
Subiran Posted November 10, 2015 Author Posted November 10, 2015 I've converted it already into decimals, what is the next step in plotting? Quote
Subiran Posted November 10, 2015 Author Posted November 10, 2015 I've already converted into decimal longitude and latitude units, can you help me the next step in plotting it to CAD? Quote
Subiran Posted November 10, 2015 Author Posted November 10, 2015 Here is our Lot, and our problem is how can we input it through Autocad or other Programs that would be accurate. Quote
eldon Posted November 10, 2015 Posted November 10, 2015 If you have taken off the Latitude and Longitude by picking points on Google Earth, I would suggest that you have the coordinates showing as Universal Transverse Mercator before you pick the points. That would allow you to use ordinary style coordinates in AutoCAD without the hassle of spherical projections. Quote
Subiran Posted November 10, 2015 Author Posted November 10, 2015 After setting it to Universal Transverse Mercator, in AUTOCAD, how can i get the right format to plot like @{distance} Quote
Subiran Posted November 10, 2015 Author Posted November 10, 2015 I have a KMZ file for this lot but i don't know how to plot it on AUTOCAD because of its coordinates which I don't know yet how to use but I am very much interested. For anyone who wants to help me, please reply me to send the KMZ file (Google Earth File) to you. Or for anyone who has VIDEO tutorial, please just post it on this Thread. Quote
eldon Posted November 10, 2015 Posted November 10, 2015 With UTM coordinates, I would draw the lot by entering each coordinate in turn, rather than drawing it by relative coordinates. I have not used KMZ files. I believe that they use spherical coordinates, which are always not so simple to draw in ordinary AutoCAD. Quote
