Hello -
New here and new to lisps. One Question: (second question was answered on another thread)
I found the xpipe and xtube lisp from another thread and it works but it has stopped working in one particular file. If I open a vanilla drawing, draw a pline, and do xpipe/xtube it works just fine. In the file I am working on however it does not want to work anymore. I have exited and reopened and reloaded the lisps. All I get in 2-d is a circle on one end of the pline. I have done audit and -purge and that still did not work. Any thoughts?
Edited by darkman257
This is not necessarily a bump but I tried this on another computer and the results are the same in regards to xpipe and xtube only displaying a circle on the x,y plane at the end of the poly line and not going along the extruded path. Is there a system variable that I might have changed for this particular file?
