KIMBO Posted November 2, 2015 Posted November 2, 2015 Hi, When importing points into a drawing all the points insert at 0,0. I think its a prototype problem but am unsure. I've had this problem before, just can't recall how to correct it. Open to suggestions. Thanks Quote
Squirltech Posted November 2, 2015 Posted November 2, 2015 Welcome to the forum. The file you're importing is PNEZD or PENZD? If so, you'll need to set the file format to correspond with that of the file being imported. Quote
KIMBO Posted November 2, 2015 Author Posted November 2, 2015 My point import setting is PNEZD. The problem started when I inserted an old drawing that had a "north to the left orintation" and I run "check points" to bring the old drawing point into my new drawing. Now, with every new drawing, imported points all insert at 0,0. Thanks Quote
