jlab13 Posted December 27, 2008 Share Posted December 27, 2008 When I go to save a new drawing, it defaults to save as a "autocad 2007" doc. Is this correct? Thanks again! Also, I just noticed that, even thought it's turned on, I can't see the Viewcube. Is there a graphic card or windows setting that could obstruct this? Thanks! Quote Link to comment Share on other sites More sharing options...
Cad64 Posted December 27, 2008 Share Posted December 27, 2008 So you're using 2009 correct? The default format for saving is 2007, but you can also save in 2004 format, 2000 format or R14 format. Autodesk changes their dwg format about every 3 years, so next year there will probably be a 2010 format. I don't use 2009 so maybe someone else can help you with your other question. And when you ask a question, please try to name your thread appropriately. I have renamed this thread to something a little more descriptive. Quote Link to comment Share on other sites More sharing options...
jlab13 Posted December 27, 2008 Author Share Posted December 27, 2008 Thank You! Quote Link to comment Share on other sites More sharing options...
jkristia Posted December 29, 2008 Share Posted December 29, 2008 I just noticed the same issue with the viewcube. I have a 2D drawing where I started to extrude some 3D shapes - now when I enable the viewcube it does not show. Quote Link to comment Share on other sites More sharing options...
jkristia Posted December 29, 2008 Share Posted December 29, 2008 ahhh - the view cube doesn't show in 2D wireframe mode, pick one ofthe other visual style modes and the cube shows Quote Link to comment Share on other sites More sharing options...
