Hippe013 Posted November 5, 2015 Share Posted November 5, 2015 Bronco15, Below is my revised code. I included (vl-load-com) this time. I don't usually worry about (vl-load-com) because it is called in other start-up lisps. I suppose it is good practice to always include this as it doesn't hurt if it is called more than once. (Just don't put it in a loop of course!) What is different in this code is I get all the points of the selected feature line through the GETPOINTS method. This requires an integer argument. I believe it is 1 for PI Points 2 for Elevation Points and 3 for all points. I want to test against all points so I use 3. I also grab all points from the feature line that I am testing against. GETPOINTS returns a variant so I need to convert this to a safearray and then to a list using both vlax-variant-value and then vlax-safearray->list. So the logic is as follows: I get a list of possible intersections. (This list may contain duplicates.) For each point in the intersections list (symbol catch) test to see if I've already processed this point (symbol proc). I don't want to process duplicate points. Next make sure the point is not a member of my selected feature line points (symbol fl-pnts). If its not a member Insert Feature Point and increment p-count. Next make sure the point is not a member of my testing feature line points (symbol f-pnts). If it isn't then Insert Feature Point and increment p-count. (vl-load-com) (defun c:FLINT ( / fl site fls p-count sa catch n proc) (setq ss (ssget "_+.:E:S" '((0 . "AECC_FEATURE_LINE")))) (if ss (progn (setq fl (vlax-ename->vla-object (ssname ss 0))) [color="red"](setq fl-pnts (vlax-safearray->list (vlax-variant-value (vlax-invoke-method fl 'GetPoints 3))))[/color] [color="red"](setq fl-pnts (FL:list->pntlist fl-pnts))[/color] (setq site (FL:FL->site fl)) (setq fls (vlax-get-property site 'Featurelines)) (setq p-count 0) (vlax-for f fls (if (not (equal f fl)) (progn (setq sa (vlax-variant-value (vlax-invoke-method fl 'IntersectWith f acExtendNone))) (setq catch (vl-catch-all-apply 'vlax-safearray->list (list sa))) (if (not (vl-catch-all-error-p catch)) (progn (setq catch (fl:list->pntlist catch)) (setq n 0) [color="red"](setq f-pnts (vlax-safearray->list (vlax-variant-value (vlax-invoke-method f 'GetPoints 3))))[/color] [color="red"](setq f-pnts (FL:list->pntlist f-pnts))[/color] (repeat (length catch) (setq p (nth n catch)) (if (not (member p proc)) (progn ;Use 2 for Elevation Point - Use 1 for PI (if[color="red"] (not (member p fl-pnts))[/color] (progn (vlax-invoke-method fl 'InsertFeaturePoint (vlax-3d-point p) 2) (fl:drx p 2) (setq proc (append proc (list p))) (setq p-count (+ p-count 1)))) (if [color="red"](not (member p f-pnts))[/color] (progn (vlax-invoke-method f 'InsertFeaturePoint (vlax-3d-point p) 2) (fl:drx p 2) (setq proc (append proc (list p))) (setq p-count (+ p-count 1)))) ) ) (setq n (+ n 1)) ) ) (progn) ) ) ) ) (princ (strcat "\nInserted " (itoa p-count) " Elevation Points.")) ) (princ "\nNothing was Selected.") ) (princ) ) (defun FL:Site->FL-ID-List (site / fls cnt ret n li) (setq fls (vlax-get-property site 'Featurelines)) (setq cnt (vlax-get-property fls 'Count)) (if (= cnt 0) (setq ret nil) (progn (setq n 0) (repeat cnt (setq li (append li (list (vlax-get-property (vla-item fls n) 'ObjectID)))) (setq n (1+ n)) ) (setq ret li) ) ) ret ) (defun FL:List->pntlist (li / newli n) (setq n 0) (repeat (/ (length li) 3) (setq newli (append newli (list (list (nth n li) (nth (+ n 1) li) (nth (+ n 2) li))))) (setq n (+ n 3)) ) newli) (defun FL:FL->Site (fl / cvlapp cvlad sites ret n site objid-list ) (setq cvlapp (vlax-get-property fl 'application)) (setq cvlad (vlax-get-property cvlapp 'ActiveDocument)) (setq sites (vlax-get-property cvlad 'Sites)) (setq ret nil) (setq n 0) (repeat (vlax-get-property sites 'Count) (setq site (vla-item sites n)) (setq objid-list (FL:Site->FL-ID-List site)) (if (member (vlax-get-property fl 'ObjectID) objid-list) (setq ret site) ) (setq n (1+ n)) ) ret ) (defun FL:drx (ctr clr / cor1 cor2 cor3 cor4 vs xs) (setq vs (getvar "viewsize")) (setq xs (/ vs 40)) (setq cor1 (polar ctr (* pi 0.25) xs)) (setq cor2 (polar ctr (* pi 0.75) xs)) (setq cor3 (polar ctr (* pi 1.25) xs)) (setq cor4 (polar ctr (* pi 1.75) xs)) (grdraw ctr cor1 clr 0) (grdraw ctr cor2 clr 0) (grdraw ctr cor3 clr 0) (grdraw ctr cor4 clr 0) ) Give this a try and see if it works as expected. regards, hippe013 Quote Link to comment Share on other sites More sharing options...
broncos15 Posted November 5, 2015 Author Share Posted November 5, 2015 Bronco15, Below is my revised code. I included (vl-load-com) this time. I don't usually worry about (vl-load-com) because it is called in other start-up lisps. I suppose it is good practice to always include this as it doesn't hurt if it is called more than once. (Just don't put it in a loop of course!) What is different in this code is I get all the points of the selected feature line through the GETPOINTS method. This requires an integer argument. I believe it is 1 for PI Points 2 for Elevation Points and 3 for all points. I want to test against all points so I use 3. I also grab all points from the feature line that I am testing against. GETPOINTS returns a variant so I need to convert this to a safearray and then to a list using both vlax-variant-value and then vlax-safearray->list. So the logic is as follows: I get a list of possible intersections. (This list may contain duplicates.) For each point in the intersections list (symbol catch) test to see if I've already processed this point (symbol proc). I don't want to process duplicate points. Next make sure the point is not a member of my selected feature line points (symbol fl-pnts). If its not a member Insert Feature Point and increment p-count. Next make sure the point is not a member of my testing feature line points (symbol f-pnts). If it isn't then Insert Feature Point and increment p-count. (vl-load-com) (defun c:FLINT ( / fl site fls p-count sa catch n proc) (setq ss (ssget "_+.:E:S" '((0 . "AECC_FEATURE_LINE")))) (if ss (progn (setq fl (vlax-ename->vla-object (ssname ss 0))) [color=red](setq fl-pnts (vlax-safearray->list (vlax-variant-value (vlax-invoke-method fl 'GetPoints 3))))[/color] [color=red](setq fl-pnts (FL:list->pntlist fl-pnts))[/color] (setq site (FL:FL->site fl)) (setq fls (vlax-get-property site 'Featurelines)) (setq p-count 0) (vlax-for f fls (if (not (equal f fl)) (progn (setq sa (vlax-variant-value (vlax-invoke-method fl 'IntersectWith f acExtendNone))) (setq catch (vl-catch-all-apply 'vlax-safearray->list (list sa))) (if (not (vl-catch-all-error-p catch)) (progn (setq catch (fl:list->pntlist catch)) (setq n 0) [color=red](setq f-pnts (vlax-safearray->list (vlax-variant-value (vlax-invoke-method f 'GetPoints 3))))[/color] [color=red](setq f-pnts (FL:list->pntlist f-pnts))[/color] (repeat (length catch) (setq p (nth n catch)) (if (not (member p proc)) (progn ;Use 2 for Elevation Point - Use 1 for PI (if[color=red] (not (member p fl-pnts))[/color] (progn (vlax-invoke-method fl 'InsertFeaturePoint (vlax-3d-point p) 2) (fl:drx p 2) (setq proc (append proc (list p))) (setq p-count (+ p-count 1)))) (if [color=red](not (member p f-pnts))[/color] (progn (vlax-invoke-method f 'InsertFeaturePoint (vlax-3d-point p) 2) (fl:drx p 2) (setq proc (append proc (list p))) (setq p-count (+ p-count 1)))) ) ) (setq n (+ n 1)) ) ) (progn) ) ) ) ) (princ (strcat "\nInserted " (itoa p-count) " Elevation Points.")) ) (princ "\nNothing was Selected.") ) (princ) ) (defun FL:Site->FL-ID-List (site / fls cnt ret n li) (setq fls (vlax-get-property site 'Featurelines)) (setq cnt (vlax-get-property fls 'Count)) (if (= cnt 0) (setq ret nil) (progn (setq n 0) (repeat cnt (setq li (append li (list (vlax-get-property (vla-item fls n) 'ObjectID)))) (setq n (1+ n)) ) (setq ret li) ) ) ret ) (defun FL:List->pntlist (li / newli n) (setq n 0) (repeat (/ (length li) 3) (setq newli (append newli (list (list (nth n li) (nth (+ n 1) li) (nth (+ n 2) li))))) (setq n (+ n 3)) ) newli) (defun FL:FL->Site (fl / cvlapp cvlad sites ret n site objid-list ) (setq cvlapp (vlax-get-property fl 'application)) (setq cvlad (vlax-get-property cvlapp 'ActiveDocument)) (setq sites (vlax-get-property cvlad 'Sites)) (setq ret nil) (setq n 0) (repeat (vlax-get-property sites 'Count) (setq site (vla-item sites n)) (setq objid-list (FL:Site->FL-ID-List site)) (if (member (vlax-get-property fl 'ObjectID) objid-list) (setq ret site) ) (setq n (1+ n)) ) ret ) (defun FL:drx (ctr clr / cor1 cor2 cor3 cor4 vs xs) (setq vs (getvar "viewsize")) (setq xs (/ vs 40)) (setq cor1 (polar ctr (* pi 0.25) xs)) (setq cor2 (polar ctr (* pi 0.75) xs)) (setq cor3 (polar ctr (* pi 1.25) xs)) (setq cor4 (polar ctr (* pi 1.75) xs)) (grdraw ctr cor1 clr 0) (grdraw ctr cor2 clr 0) (grdraw ctr cor3 clr 0) (grdraw ctr cor4 clr 0) ) Give this a try and see if it works as expected. regards, hippe013 This code is awesome. I tested it out and it seems to work perfectly. I want to make sure that I understand it correctly: [color=black](setq f-pnts (vlax-safearray->list (vlax-variant-value (vlax-invoke-method f 'GetPoints 3))))[/color] [font=Segoe UI][size=2] [font=Segoe UI][size=2] This is making a list of all the different 3d points (both elevation points and PI's). You then have the code test in the if statement whether the point is in your list, and if not, then you insert an elevation point. Thank you so much for making and sharing this! I know it will save me a lot of time grading. [/size][/font][/size][/font] Quote Link to comment Share on other sites More sharing options...
robert06 Posted May 19, 2017 Share Posted May 19, 2017 Hi, It's a useful lisp! What should be changed, if I wanted PI's not elevation points inserted. Thank you Robert Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted May 19, 2017 Share Posted May 19, 2017 I'm glad you find this Lisp useful. Look for the method 'InsertFeaturePoint, change the 2 to a 1. That should do the trick. Quote Link to comment Share on other sites More sharing options...
robert06 Posted May 24, 2017 Share Posted May 24, 2017 Great, Thank you! Robert Quote Link to comment Share on other sites More sharing options...
