Convert Layout to Model Space with Autocad 2007
Hi, everybody.
I'm using Autocad 2007. I want export file at layout to model in autocad 2007 but I can not.
Please help me.
Thank you.
exporttolayout.dwg
Is the problem that there is no EXPORTLAYOUT command in AutoCAD 2007? I haven't checked.
OK...now I have checked and as I understand it the EXPORTLAYOUT command was first introduced in AutoCAD 2008.
Since it appears you also have 2014 why can't you export to layout, open the layout in a new drawing then do a "save as" to 2007 file format?
Edited by ReMark
Dear, ReMark.
Yes, EXPORTLAYOUT don't work in autocad 2007. Only autocad 2010+ EXPORTLAYOUT.
At home, I'm using autocad 2007. At office , I'm using autocad 2015.
Please, help me.
Thank you.
As I mentioned earlier that command was introduced in AutoCAD 2008. Why aren't you doing this using AutoCAD 2014 which your profile says is what you are running?
My home away from the office so I can not go to the company at this time.
Everyone has a story. Wait right there.
Here you go....one exported-layout-to-model-space saved in 2007 file format.
humg exported dwg.dwg
By the way, please pay attention to where you post your questions. This one was in the AutoCAD Customization forum. Not sure why.
[ATTACH]55954[/ATTACH]
Thank ReMark,
Good luck for you.
The problem is that I am doing at home and there are many files. Please give me a solution.
Don't thank me yet. You haven't opened the drawing.
I opened the file you sent.
Another satisfied customer.
You're welcomed.
