The text should be flipped horizontally. In works.dwg it does, in doesntwork.dwg it does not. Nothing happens when you try to flip the attribute horizontally in doesntwork.dwg.
What do you mean by "correctly named"?
Oh, I just got what you mean. Yes, they are named correctly.
Edited by tchwiesz
That's not the issue - You need to do a double flip (one horizontally and one vertically) for when the arrow points certain directions (try pointing the arrow to the top left). The text needs to be able to flip horizontally.
You definately have something strange going on in that drawing. Pure guesswork, I would say it has something to do with layer 0 being frozen, but there is also a warning about proxy graphics and with LT I have no idea what that could be, and the UCS is rotated.
Yeah, I noticed that actually. Same thing seems to happen when I paste it to a brand new drawing though - No flipping...
Figured it out - Need to change the MIRRTEXT variable to 1!
I would just flip the arrow and leave the text alone, no need to mess with mirrtext.
