Baber62 Posted October 26, 2015 Posted October 26, 2015 I am looking for lisp routine to list duplicate points in a drawing. I have managed to find ones which can remove duplicate points but not any that can list duplicate points. Thanks for your assists in advance. Quote
David Bethel Posted October 26, 2015 Posted October 26, 2015 Are you talking about POINT entities ? What tolerance do you need ? Are layers considered ? Colors ? -David Quote
Baber62 Posted October 27, 2015 Author Posted October 27, 2015 Hi David, Yes I am talking about point entities. The tolerance I would be looking at is the exact co-ordinates of the points say from either a topographical survey or from GIS Mapping converted to AutoCAD points. I have looked at layers and it does seem that some of the points have been entered in twice at some co-ordinates. Tolerances would need to be 0.001 working in metres. Although I think I have found the answer after searching on this last night on CADTutor. David you answered in the following link. http://www.cadtutor.net/forum/showthread.php?94248-Selecting-Duplicate-Points/page2 However, I need to generate a list showing the duplicate co-ordinates which can then be exported as a csv file. Any ideas would be appreciated. Quote
Lee Mac Posted October 27, 2015 Posted October 27, 2015 The following is untested but should perform as required: (defun c:listdupepoints ( / d f i l s ) (if (setq s (ssget '((0 . "POINT")))) (progn (repeat (setq i (sslength s)) (setq p (cdr (assoc 10 (entget (ssname s (setq i (1- i))))))) (if (vl-some (function (lambda ( x ) (equal p x 1e-3))) l) (setq d (cons p d)) (setq l (cons p l)) ) ) (cond ( (not d) (princ "\nNo duplicate points found.") ) ( (not (setq f (getfiled "" "" "csv" 1))) (princ "\n*Cancel*") ) ( (setq f (open f "w")) (foreach p d (write-line (apply 'strcat (mapcar '(lambda ( x y ) (strcat (rtos x) y)) p '("," "," "")) ) f ) ) (close f) ) ( (princ "\nUnable to open file for writing.")) ) ) ) (princ) ) Quote
symoin Posted January 19, 2024 Posted January 19, 2024 On 10/27/2015 at 12:40 PM, Lee Mac said: The following is untested but should perform as required: (defun c:listdupepoints ( / d f i l s ) (if (setq s (ssget '((0 . "POINT")))) (progn (repeat (setq i (sslength s)) (setq p (cdr (assoc 10 (entget (ssname s (setq i (1- i))))))) (if (vl-some (function (lambda ( x ) (equal p x 1e-3))) l) (setq d (cons p d)) (setq l (cons p l)) ) ) (cond ( (not d) (princ "\nNo duplicate points found.") ) ( (not (setq f (getfiled "" "" "csv" 1))) (princ "\n*Cancel*") ) ( (setq f (open f "w")) (foreach p d (write-line (apply 'strcat (mapcar '(lambda ( x y ) (strcat (rtos x) y)) p '("," "," "")) ) f ) ) (close f) ) ( (princ "\nUnable to open file for writing.")) ) ) ) (princ) ) Hi, can it select the duplicate points (more than 1 on the same position) keeping one at its position and to paste it to another dwg (ctr+c and ctr+v) for checking Quote
Lee Mac Posted January 19, 2024 Posted January 19, 2024 1 hour ago, symoin said: can it select the duplicate points (more than 1 on the same position) keeping one at its position and to paste it to another dwg (ctr+c and ctr+v) for checking Sure - try this (untested): (defun c:listdupepoints ( / d e i l p s ) (if (setq s (ssget '((0 . "POINT")))) (progn (setq d (ssadd)) (repeat (setq i (sslength s)) (setq i (1- i) e (ssname s i) p (cdr (assoc 10 (entget e))) ) (if (vl-some (function (lambda ( x ) (equal p x 1e-3))) l) (ssadd e d) (setq l (cons p l)) ) ) (if (zerop (sslength d)) (princ "\nNo duplicate points found.") (sssetfirst nil d) ) ) ) (princ) ) 1 Quote
