teknomatika Posted October 20, 2015 Share Posted October 20, 2015 I have this routine (unknown to the author). Thank you for your help with the following change: Export the list of layers but only on a selection. (defun c:LL2T ( / oecho clrlst dwgnm fn fh lyr lyrlst) (defun chkbit (bit_val num) (not (zerop (logand bit_val num))) ) (setq oecho (getvar "cmdecho") clrlst (list (cons 1 "RED") (cons 2 "YELLOW") (cons 3 "GREEN") (cons 4 "CYAN") (cons 5 "BLUE") (cons 6 "MAGENTA") (cons 7 "WHITE") ) dwgnm (getvar "dwgname") ) (setvar "cmdecho" 0) (setq fn (getfiled " File name: " (strcat dwgnm ".LS") "LS" (+ 1 2)) ) (while (setq lyr (tblnext "layer" (not lyr))) (setq lyrlst (cons (cdr (assoc 2 lyr)) lyrlst)) ) (setq lyrlst (acad_strlsort lyrlst)) (princ "\nWriting layer data to file...") (setq fh (open fn "w")) (princ (strcat dwgnm ".DWG\n") fh) (foreach x lyrlst (setq lyr (tblsearch "layer" x) lyrname (cdr (assoc 2 lyr)) lyrclr (cdr (assoc 62 lyr)) lyrlt (cdr (assoc 6 lyr)) frzn? (chkbit 1 (cdr (assoc 70 lyr))) lokd? (chkbit 4 (cdr (assoc 70 lyr))) ) (if (minusp lyrclr) (setq on? "OFF" lyrclr (abs lyrclr) ) (setq on? "ON") ) (if (assoc lyrclr clrlst) (setq lyrclr (cdr (assoc lyrclr clrlst))) ) (if frzn? (setq frzn? "FROZEN") (setq frzn? "THAWED") ) (if lokd? (setq lokd? "LOCKED") (setq lokd? "UNLOCKED") ) (princ lyrname fh) ;;(princ "," fh) ;;(princ lyrclr fh) ;;(princ "," fh) ;;(princ lyrlt fh) ;;(princ "," fh) ;;(princ on? fh) ;;(princ "," fh) ;;(princ frzn? fh) ;;(princ "," fh) ;;(princ lokd? fh) (princ "\n" fh) ) (princ "done.") (close fh) (setvar "cmdecho" oecho) (princ) ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 20, 2015 Share Posted October 20, 2015 Here is a similar program with a few more options - also, note that you can select layers from the Layer Manager and copy them directly. Quote Link to comment Share on other sites More sharing options...
teknomatika Posted October 20, 2015 Author Share Posted October 20, 2015 Lee, fantastic tool, as expected. Thank you for your statement. Already I kept. However, for this, I just want to extract the names of the layers contained in a selection, not the entire design. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 20, 2015 Share Posted October 20, 2015 Maybe something like this? (defun c:layernames ( / f l s x ) (if (and (setq s (ssget)) (setq f (getfiled "Create File" "" "txt" 1)) ) (if (setq f (open f "w")) (progn (repeat (setq i (sslength s)) (or (member (setq x (cdr (assoc 8 (entget (ssname s (setq i (1- i))))))) l) (and (write-line x f) (setq l (cons x l)) ) ) ) (close f) ) (princ "\nUnable to open file for writing.") ) ) (princ) ) [untested] Quote Link to comment Share on other sites More sharing options...
teknomatika Posted October 21, 2015 Author Share Posted October 21, 2015 Lee, that's exactly. Better, just even making out the list sorted alphabetically. Thank you! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 21, 2015 Share Posted October 21, 2015 Lee, that's exactly. Better, just even making out the list sorted alphabetically. Thank you! You're welcome! - For an alphabetically sorted output, try the following: (defun c:layernames ( / f l s x ) (if (and (setq s (ssget)) (setq f (getfiled "Create File" "" "txt" 1)) ) (if (setq f (open f "w")) (progn (repeat (setq i (sslength s)) (or (member (setq x (cdr (assoc 8 (entget (ssname s (setq i (1- i))))))) l) (setq l (cons x l)) ) ) (foreach x (acad_strlsort l) (write-line x f)) (close f) ) (princ "\nUnable to open file for writing.") ) ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
teknomatika Posted October 21, 2015 Author Share Posted October 21, 2015 Lee, you're the best. But also generous. Thank you! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 21, 2015 Share Posted October 21, 2015 ........ 1 Quote Link to comment Share on other sites More sharing options...
