Hippe013 Posted October 14, 2015 Posted October 14, 2015 Hello everyone! I am very familiar with VLISP, but extremely new to vb.NET. I am trying to write a simple measuring tool to display the results to a palette. Imports System.Runtime Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput ' This line is not mandatory, but improves loading performances <Assembly: CommandClass(GetType(AutoCAD_VB_plug_in1.MyCommands))> Namespace AutoCAD_VB_plug_in1 Public Class MyCommands Public ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor 'Polar Function Public Shared Function polar(ByVal p0 As Point3d, ByVal ang As Double, ByVal dist As Double) Return New Point3d(p0.X + dist * Math.Cos(ang), _ p0.Y + dist * Math.Sin(ang), _ p0.Z) End Function 'Drawx Function Public Sub drawX(ByVal p0 As Point3d, ByVal clr As Integer) Dim vs As Double = (Application.GetSystemVariable("VIEWSIZE") / 40.0) Dim p1 As Point3d = polar(p0, (Math.PI * 0.25), vs) Dim p2 As Point3d = polar(p0, (Math.PI * 0.75), vs) Dim p3 As Point3d = polar(p0, (Math.PI * 1.25), vs) Dim p4 As Point3d = polar(p0, (Math.PI * 1.75), vs) ed.DrawVector(p0, p1, clr, False) ed.DrawVector(p0, p2, clr, False) ed.DrawVector(p0, p3, clr, False) ed.DrawVector(p0, p4, clr, False) End Sub Friend Shared m_ps As Autodesk.AutoCAD.Windows.PaletteSet = Nothing Friend Shared mypalette As UserControl1 = New UserControl1() <CommandMethod("NewAX")> _ Public Sub NewAX() If m_ps Is Nothing Then m_ps = New Autodesk.AutoCAD.Windows.PaletteSet("My Palette") m_ps.Add("My Palette", mypalette) End If If m_ps.Visible = False Then m_ps.Visible = True End If pickpoints() End Sub Public Sub pickpoints() Dim opt As PromptPointOptions = New PromptPointOptions("") opt.Message = vbCrLf & "Select First Point: " Dim ret As PromptPointResult ret = ed.GetPoint(opt) If ret.Status = PromptStatus.OK Then Dim p0 As Point3d = ret.Value drawX(p0, 2) opt.Message = vbCrLf & "Select Second Point: " opt.BasePoint = p0 opt.UseBasePoint = True ret = ed.GetPoint(opt) If ret.Status = PromptStatus.OK Then Dim p1 As Point3d = ret.Value drawX(p1, 2) Else Dim p0X As Double = p0.X Dim p0Y As Double = p0.Y Dim p0Z As Double = p0.Z mypalette.Label1.Text = "Northing: " & p0Y.ToString("N3") mypalette.Label2.Text = "Easting: " & p0X.ToString("N3") mypalette.Label3.Text = "Elevation: " & p0Z.ToString("N3") End If End If End Sub End Class End Namespace What I am finding is that when I run 'NEWAX' the palette is displayed but it then cancels my command. When I rerun the command it continues as I expected. So far I have only written what happens when the user cancels after selecting the first point. This part works and I will fill in the gaps later. The trouble is that it cancels the command if the palette isn't displayed. Any help is appreciated & if you care to comment and give pointers on the rest of the code that is welcome as well. regards, Hippe013 Quote
