CafeJr Posted October 13, 2015 Posted October 13, 2015 Hi to everyone!... Someone knows a Lisp to plot a internal sheets of a model space file? Eg.: I have a dwg file with 10 sheets internal, I know how to put name at each sheet (NEWVIEW) and it appears at same place of Extend, Display or Window at plot configuration screen. If I put names as a numbers: 1, 2, 3,..., 10, it's possible to select one page or all to plot at the same time? Or create a Lisp that can help it!?... Thanks in advance!... Its possible using a comand: -plot Detailed plot configuration? [Yes/No] : y Enter a layout name or [?] : Enter an output device name or [?] : Canon iR2525 Enter paper size or [?] : Enter paper units [inches/Millimeters] : m Enter drawing orientation [Portrait/Landscape] : Plot upside down? [Yes/No] : Enter plot area [Display/Extents/Limits/View/Window] : v Enter view name : 3 (the view name) Enter plot scale (Plotted Millimeters=Drawing Units) or [Fit] : Enter plot offset (x,y) or : c Plot with plot styles? [Yes/No] : Enter plot style table name or [?] (enter . for none) : Plot with lineweights? [Yes/No] : Enter shade plot setting [As displayed/legacy Wireframe/legacy Hidden/Visual styles/Rendered] : Write the plot to a file [Yes/No] : Save changes to page setup [Yes/No]? Proceed with plot [Yes/No] : Quote
BIGAL Posted October 14, 2015 Posted October 14, 2015 Have a look at this I think you imply all is in model space. this is plot all in model space could be changed to views, plotting a range is achieveable by checking sheet id 1,2 ,3 etc Check my post http://www.cadtutor.net/forum/showthread.php?67143-One-Click-Printing Quote
CafeJr Posted October 14, 2015 Author Posted October 14, 2015 BIGAL said: Have a look at this I think you imply all is in model space. this is plot all in model space could be changed to views, plotting a range is achieveable by checking sheet id 1,2 ,3 etc Check my post http://www.cadtutor.net/forum/showthread.php?67143-One-Click-Printing Thanks Bigal!... Its help me alot!... Is exactly that I was looking for!... Quote
CafeJr Posted October 15, 2015 Author Posted October 15, 2015 Bigal, do you know if is possible to get more than one item to select to print? At the first code!... Quote
BIGAL Posted October 16, 2015 Posted October 16, 2015 If you look at my post in link above its a plot all. To only plot a few would require checking the sheet number an extra coding step. Or do by pick it would be easy to change the code to 1 at a time. Try (setq ss2 (ssget "x" '((0 . "INSERT") replace with (setq ss2 (ssget "M" '((0 . "INSERT") Quote
CafeJr Posted October 16, 2015 Author Posted October 16, 2015 BIGAL said: If you look at my post in link above its a plot all. To only plot a few would require checking the sheet number an extra coding step. Or do by pick it would be easy to change the code to 1 at a time. Try (setq ss2 (ssget "x" '((0 . "INSERT") replace with (setq ss2 (ssget "M" '((0 . "INSERT") Thanks Bigal!... It helps!.. Someone knows how to do it to the Code at post #2 http://www.cadtutor.net/forum/showthread.php?67143-One-Click-Printing&p=459450&viewfull=1#post459450 Quote
BIGAL Posted October 19, 2015 Posted October 19, 2015 There are many ways to pick which ones as I said before I would use a range of sheets to be plotted eg 7-10 and it would check each one picked in the "all" but only plot those within the range. See this example for layouts go down it has multiple layout routines. http://www.cadtutor.net/forum/showthread.php?84430-Move-layout-Rename-layouts-Goto-layout Quote
CafeJr Posted October 19, 2015 Author Posted October 19, 2015 BIGAL said: There are many ways to pick which ones as I said before I would use a range of sheets to be plotted eg 7-10 and it would check each one picked in the "all" but only plot those within the range. See this example for layouts go down it has multiple layout routines. http://www.cadtutor.net/forum/showthread.php?84430-Move-layout-Rename-layouts-Goto-layout Bigal!... Thanks a lot!!!... Quote
