Efeezy Posted October 6, 2015 Share Posted October 6, 2015 I don't have admin rights on my work computer so I can't put the DCL file in the support folder. Is there another way Autocad can access or find the DCL folder in another location? If so can someone walk me though the steps? I have spent a few hours on google and came up with nothing Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 6, 2015 Share Posted October 6, 2015 You can save it to your working directory (the directory of the current drawing - DWGPREFIX sys var). Quote Link to comment Share on other sites More sharing options...
Efeezy Posted October 6, 2015 Author Share Posted October 6, 2015 I am not sure what to do. I saved it on there server F:\CAD Admin\Arch Tools\Scripts. This is the location of the LISP and DCL files on our server. I also checked the tool/ options/ support file search path =F:\CAD Admin\Arch Tools\Scripts. I am still getting a load error Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted October 7, 2015 Share Posted October 7, 2015 It as happened with me too... Try it by saving on local drive (not on OS drive) Quote Link to comment Share on other sites More sharing options...
rlx Posted October 7, 2015 Share Posted October 7, 2015 (edited) Use (getvar "SAVEFILEPATH") In my CT routine you can find example in the CT_init section (defun CT_Init () (vl-load-com) (setq CT-DclName (strcat (getvar "SAVEFILEPATH") "CT.dcl")) (ct_write_dialog) (setq CT-Dcl (load_dialog CT-DclName)) (setq CT-IniFileName (strcat (getvar "SAVEFILEPATH") "CT.ini")) (defun CT_Error (s)(princ s)(setq *error* CT-OldError)(CT_Exit)(princ)) (setq CT-OldError *error* *error* CT_Error) (CT_MakeIniSettings)(CT_ReadIniSettings)(CT_ReadLastDataFile) ) Our IT guy here tries to lock almost anything and after years of 'battle' , this (savefilepath) is the only thing he hasn't been able to disable ;-) gr.Rlx Edited October 7, 2015 by rlx Quote Link to comment Share on other sites More sharing options...
kpblc Posted October 7, 2015 Share Posted October 7, 2015 Also you can use temporary files firectory to write any file(s) Quote Link to comment Share on other sites More sharing options...
rlx Posted October 7, 2015 Share Posted October 7, 2015 (edited) I don't have admin rights on my work computer so I can't put the DCL file in the support folder. Is there another way Autocad can access or find the DCL folder in another location? If so can someone walk me though the steps? I have spent a few hours on google and came up with nothing And if you really want to be bad , just make your own profile via the options command. There you can set your own paths. Also , if you can place one of your own folders at the top of the searchfilepath , you could then place there your own acad.lsp. I did all of the above , yes , I'm bad , a bad bad dragon:twisted: ps if your administrator has 'unwilling' profile : http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Start-AutoCAD-with-different-profiles.html Gr. Rlx Edited October 7, 2015 by rlx Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 7, 2015 Share Posted October 7, 2015 I am not sure what to do. I saved it on there server F:\CAD Admin\Arch Tools\Scripts. This is the location of the LISP and DCL files on our server. I also checked the tool/ options/ support file search path =F:\CAD Admin\Arch Tools\Scripts. I am still getting a load error Does your code specify a full path in the load_dialog expression, or just a filename? You may need to add a findfile expression to the code, as findfile will search the working directory, whereas I believe the load_dialog function will only search the AutoCAD support file search paths. Could you post the section of code which locates & loads the dialog? Quote Link to comment Share on other sites More sharing options...
