xmfrancis Posted October 6, 2015 Posted October 6, 2015 Hi, I create X-Y grids and after I make changes I want them to revise on the grids. Is this possible? Thank you. Edit: Also, I notice after creating the grids the labels act like text objects rather than 'special' objects. Quote
Kemphas Posted October 12, 2015 Posted October 12, 2015 You define your grid in the properties of the project, the properties are propagated to the new drawings when you insert them or via the compare properties tool. If you want to change your grid sizes you can edit it in the project and apply the properties to all respective drawings rather then doing it manually. utilizing commands like: aeupdatesigref aeupdatesxref aexref will update the annotations on the drawings respective to your new grid configurations. Quote
