Using AutoCAD 2013 & Visual Basic in VS 2010.
I get the message Epermanenly Erased in the following code.
Dim ObjAcadId As ObjectId()
MsgBox("Ref Block FAULT")
ObjAcadId = idArray ' SINGLE BLOCK CHANGE IN SELECTION SET
MsgBox("Ref Block FAULT-1")
For Each blkId As ObjectId In ObjAcadId ' idArray for individual blocks
MsgBox("Ref Block FAULT-2")
Dim blkRef As BlockReference = DirectCast(tr.GetObject(blkId, OpenMode.ForRead), BlockReference)
MsgBox("Ref Block FAULT-3")
The code has problems going form message "Ref Block Fault-2" to "Ref Block Fault-3"
I think it has something to do with blkId variable.
Any Suggestion on how to trouble shoot this?
Thank you,
