selection set of line, circle, arc, polyline from autocad 3D object
i have a 3D object in autocad and i want to create selection set of line, circle, arc, polyline of that object using visual lisp.
please help..
thanks in advance...
Drawing1.dwgUnavailable
For Example :-
Selection set of circle:-
(ssget '((0 . "circle")))
Selection set of polyline:-
(ssget '((0 . "*polyline")))
Selection set of arc:-
(ssget '((0 . "arc")))
and you can combine them like this:-
(ssget '((0 . "arc,circle,line,*polyline")))
please help..
[ATTACH]55664[/ATTACH][ATTACH]55664[/ATTACH]
what are you trying to accomplish upon selecting those entity? do you just want to select them?
(setq selset
   (ssget
     (list
       (cons -4 "<OR")
         (cons 0 "ARC")
         (cons 0 "CIRCLE")
         (cons 0 "ELLIPSE")
         (cons 0 "LINE")
         (cons 0 "LWPOLYLINE")
         (cons 0 "POINT")
         (cons 0 "POLYLINE")
       (cons -4 "OR>")
anyway in your attached drawing, i cant find any entity there except the 3D solid object.
sir, i have a 3D solid object so first what i do to convert them in a any entity?
if you are familiar with SOLPROF command you can accomplish that but if your not, here we go, it is faily easy.
Open your drawing,
go to any of your Layout
Create a Viewport > Single "choose a view you want to have a 2D profile"
type MSPACE > ENTER
Use SOLPROF > ENTER > Select 3D Solid > ENTER > ENTER > ENTER
now goto Model Space and move your 3D object so you can see the 2D profile
see snapshot
upper > 2D profile
lower > 3D Object
by the way, you need to explode the 2d profile so you can change the linetype etc.
I believe what the OP wants to achieve is extracting the edges of the solid. The use of SOLIDEDIT would achieve this.
i want feature extraction like as shown attached file(doc1.docx) using autocad and visuallispDoc1.docx
To the best of my knowledge it is not possible to extract the edges of a solid using lisp.
sure there is. I put this together from another lisp so you'll have to go through and adjust but it's a start
 (lambda ( e / g )
   (if e
       (setq g (entget (cdr (assoc 360 (entget (cdr (assoc 350 (entget e))))))))
       (mapcar (function cdr)
         (vl-remove-if-not
           (function
             (lambda ( x )
               (eq (car x) 360)
           ) g
 ) (car (entsel "\nSelect a solid: "))
Are you saying that what is left is a list of assoc 360 entities and that these entities are the edges of the solid? I ran your code, with some edits, and I am left with just one entity ACAD_EVALUATION_GRAPH. Could you explain more as to what your code is doing?
I fear I'm mistaken. I was sure this would bring back results. (I'm embarrassed). This doesn't mean the information you seek cannot be accessed via lisp. It just means I'm not the man for this job. Sorry for the quick uneducated response
the programme listed below extract hole in the 3D drawing. can i extract other type of hole(squre or triangle) using this code with some modification.
(vl-load-com)
(defun c:test (/ i e p1 p2 ss lst q var f fn dat dat1)
;hanhphuc 2014
 (set 'var (getvar 'cmdecho ))
 (setvar 'cmdecho 0)
 (if (and (setq e (entsel "\nPlease select solid.. ")) (setq e (car e)) (= (cdr (assoc 0 (entget e))) "3DSOLID"))
   (progn (vla-GetBoundingBox (setq obj (vlax-ename->vla-object e)) 'p1 'p2)
   (mapcar ''((a b) (set a (vlax-safearray->list b))) '(p1 p2) (list p1 p2))
   (command "_explode" e)
   (setq i   0
	 ss  (ssget "C" p1 p2)
	 lst (mapcar '(lambda(x)
			(setq q nil)
			(if
			 (= (cdr (assoc 0 (entget x))) "REGION")
			 (setq q (cons (LM:reg x) q))
			 (setq q (cons (vlax-ename->vla-object x) q))
			(if
			 (listp q)
			 (LM:flatten q)
			 q
		     (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
		     ) ;_ end of mapcar
	 ) ;_ end of setq
   (foreach o (vl-remove-if-not ''((x) (= (vla-get-ObjectName x) "AcDbCircle")) (LM:flatten lst))
     (setq dat(cons (princ (strcat "\nCIRCLE_" (itoa (setq i (1+ i))) " "
	     (vl-princ-to-string
		 (mapcar ''((x)(vlax-get o x)) '(Radius Center))
		     dat))
     ) ;_ end of foreach
   (command "_.U")
(setq fn (strcat (getvar "dwgprefix") "hole dat.csv") f (open fn "w"))
; If you don't want to override file ,to append use (open fn "a") as suggested by Marko @ post#14
(foreach $
(foreach x dat
 (setq	dat1 (cons (vl-string-translate
	     (vl-list->string
	       (vl-remove-if ''((a) (or (= a 10) (= a 40) (= a 41))) (vl-string->list x))
	       ) ;_ end of vl-list->string
	     ) ;_ end of vl-string-translate
	   dat1
	   ) ;_ end of cons
) ;_ end of setq
 ) ;_ end of foreach
(write-line $ f))
(write-line " " f)
(if f (close f))
(startapp "notepad" fn)     ;<--remove this line if you don't want it to pop-up everytime
   ) ;_ end of progn
   ) ;_ end of if
 (setvar 'cmdecho var)
 ) ;_ end of defun
;;;[url]http://www.cadtutor.net/forum/showthread.php?35506-How-to-get-Region-coordinates/page2[/url]
;;;adopted as sub-function
(defun LM:reg (reg / RetObj)
 (setq Reg (vlax-ename->vla-object reg))
 (if (vlax-method-applicable-p reg 'explode)
 (setq RetObj (vlax-safearray->list (vlax-variant-value (vla-explode Reg))))
 (repeat (length RetObj)
   (if	(eq "AcDbRegion" (vla-get-ObjectName (car RetObj)))
     (setq RetObj (append RetObj (vlax-safearray->list (vlax-variant-value (vla-explode (car RetObj))))))
     (setq RetObj (append RetObj (list (car RetObj))))
     ) ;_ end of if
   (setq RetObj (cdr RetObj))
   ) ;_ end of repeat
 retobj
 ) ;_ end of defun
;; Flatten List  -  Lee Mac
;; Transforms a nested list into a non-nested list
;; [url]http://www.lee-mac.com/flatten.html[/url]
(defun LM:flatten ( l )
   (if (atom l)
       (list l)
       (append (LM:flatten (car l)) (if (cdr l) (LM:flatten (cdr l))))
Edited by SLW210
Code Tags
