big daddy Posted December 24, 2008 Posted December 24, 2008 I have to change a bunch of circles to points so that the dxf can be uploaded to a CNC router (for drilling). Anyone know of a way to quickly select all circles then change them to points or at the very least add points to the center of each circle? Quote
lpseifert Posted December 24, 2008 Posted December 24, 2008 Merry Christmas (defun c:test () (setvar "cmdecho" 0) (setq ss1 (ssget '((0 . "circle"))) sslen (sslength ss1) cnt 0 ) (if (> sslen 32767) (alert "You've selected more than 32,767 circles!!!") (progn (repeat sslen (setq ename (ssname ss1 cnt) edata (entget ename) rp (cdr (assoc 10 edata)) ) ;(command "point" rp) (entmake (list (cons 0 "point") (cons 10 rp) ) ) (setq cnt (1+ cnt)) (entdel ename) ;remove this line if you want to keep the circles ) ) ) (setvar "cmdecho" 1) (princ) ) Quote
Lee Mac Posted December 25, 2008 Posted December 25, 2008 1 opening brack missed ~ Merry Christmas lpseifert ;Circles to Points by Lpseifert (defun c:test (/ ss1 sslen cnt ename edata rp) (setq ss1 (ssget '((0 . "circle"))) sslen (sslength ss1) cnt 0 ) ;_ end setq (repeat sslen (setq ename (ssname ss1 cnt) edata (entget ename) rp (cdr (assoc 10 edata)) ) ;_ end setq (command "point" rp) (setq cnt (1+ cnt)) (entdel ename) ;remove this line if you want to keep the circles ) ;_ end repeat (princ) ) ;_ end defun Quote
David Bethel Posted December 25, 2008 Posted December 25, 2008 Just as an aside, if there are more than 32767 entities in a PICKSET, (sslength) returns a real, not an integer as the documentation states and will make (repeat) crash due to a bad argument. Happy Holidays! -David PS At least it did up until A2K Quote
VVA Posted December 26, 2008 Posted December 26, 2008 Try it The program changes a set of primitive things for the chosen primitive thing. Application examples: Replacement of one blocks with others. Replacement of points with blocks or circles. Replacement of one inscriptions with others. At first it is necessary to choose replaced objects and to press Enter, then to specify replacing object. The insert is made in the centre of a limiting (dimensional) rectangle of old objects. New objects are inserted into layers which to which old objects belonged. This programm posted {Smirnoff} (on this forum known as ASMI) here (defun c:frto(/ ACTDOC COPOBJ ERRCOUNT EXTLST EXTSET FROMCEN LAYCOL MAXPT CURLAY MINPT OBJLAY OKCOUNT OLAYST SCLAY TOCEN TOOBJ VLAOBJ *ERROR*) (vl-load-com) (defun *ERROR*(msg) (if olaySt (vla-put-Lock objLay olaySt) ); end if (vla-EndUndoMark actDoc) (princ) ); end of *ERROR* (defun GetBoundingCenter(vlaObj / blPt trPt cnPt) (vla-GetBoundingBox vlaObj 'minPt 'maxPt) (setq blPt(vlax-safearray->list minPt) trPt(vlax-safearray->list maxPt) cnPt(vlax-3D-point (list (+(car blPt)(/(-(car trPt)(car blPt))2)) (+(cadr blPt)(/(-(cadr trPt)(cadr blPt))2)) 0.0 ); end list ); end vlax-3D-point ); end setq ); end of GetBoundingCenter (if(not(setq extSet(ssget "_I"))) (progn (princ "\n+++ Select distination objects and press Enter <- ") (setq extSet(ssget)) ); end progn ); end if (if(not extSet) (princ "\nDistination objects isn't selected!") ); end if (if (and extSet (setq toObj(entsel "\n+++ Select source object -> ")) ); and and (progn (setq actDoc (vla-get-ActiveDocument (vlax-get-Acad-object)) layCol (vla-get-Layers actDoc) extLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex extSet)))) vlaObj(vlax-ename->vla-object(car toObj)) objLay(vla-Item layCol (vla-get-Layer vlaObj)) olaySt(vla-get-Lock objLay) fromCen(GetBoundingCenter vlaObj) errCount 0 okCount 0 ); end setq (vla-StartUndoMark actDoc) (foreach obj extLst (setq toCen(GetBoundingCenter obj) scLay(vla-Item layCol (vla-get-Layer obj)) );end setq (if(/= :vlax-true(vla-get-Lock scLay)) (progn (setq curLay(vla-get-Layer obj)) (vla-put-Lock objLay :vlax-false) (setq copObj(vla-copy vlaObj)) (vla-Move copObj fromCen toCen) (vla-put-Layer copObj curLay) (vla-put-Lock objLay olaySt) (vla-Delete obj) (setq okCount(1+ okCount)) ); end progn (setq errCount(1+ errCount)) ); end if ); end foreach (princ (strcat "\n" (itoa okCount) " were changed. " (if(/= 0 errCount) (strcat (itoa errCount) " were on locked layer! ") "" ); end if ); end strcat ); end princ (vla-EndUndoMark actDoc) ); end progn (princ "\nSource object isn't selected! ") ); end if (princ) ); end of c:frto Quote
BIGAL Posted January 1, 2009 Posted January 1, 2009 Hi guys for Lee Mac as above a simple bracket checker nothing worse than when you write code and you have to find a missing bracket it can often be frustrating. (defun c:chkbrk (/ opf bkt chekdfile rdctl wkfile currentln wln ltr ncln) (setvar "cmdecho" 0) (prompt "\nlook at end of line") ;(setq chekdfile (getstring "enter name of file :")) (SETQ chekdfile (getfiled "Enter file name:" " " "LSP" 4)) (setq opf (open chekdfile "r")) (setq bkt 0) (setq blkl 0) (setq rdctl 1) (setq wkfile (open "wow.lsp" "w")) (setq currentln "a") (while (/= blkl 6) (setq currentln (read-line opf)) (if (= currentln nil)(setq currentln "")) (if (= currentln "")(setq blkl (+ 1 blkl))(setq blkl 1)) (setq wln currentln) (while (/= wln "") (setq ltr (substr wln 1 1)) (setq wln (substr wln 2)) (cond ((= (ascii ltr) 34) (if (= rdctl 0)(setq rdctl 1)(setq rdctl 0))) ((and (= ltr "(")(= rdctl 1))(setq bkt (+ bkt 1))) ((and (= ltr ")")(= rdctl 1))(setq bkt (- bkt 1))) ((and (= ltr ";")(= rdctl 1))(setq wln "")) ;(t (prompt ltr)) ) ) (setq ncln (strcat currentln ";" (itoa bkt) (princ (itoa bkt)) (if (= rdctl 0) "string open" ""))) (if (/= currentln "")(write-line ncln wkfile)) ) (close wkfile) (close opf) (prompt (strcat "open brakets= " (itoa bkt) ".")) ) ang1 nil pt1 nil pt2 nil pt3 nil pt4 nil pt5 nil) (princ) Quote
ASMI Posted January 1, 2009 Posted January 1, 2009 With list instead selection set: (defun c:ctp(/ cSet) (and(setq cSet(ssget '((0 . "CIRCLE")))) (mapcar '(lambda(x)(vl-cmdf "_.POINT"(cdr(assoc 10(entget x))))(entdel x)) (vl-remove-if 'listp(mapcar 'cadr(ssnamex cSet))))) (princ) ); end of c:ctp Quote
David Bethel Posted January 1, 2009 Posted January 1, 2009 AS IS [b][color=BLACK]([/color][/b]defun c:cir2poi [b][color=FUCHSIA]([/color][/b]/ ss i en ed nd[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=BLUE]([/color][/b]not ss[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]princ "\nSelect CIRCLEs To Convert To POINTs..."[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]setq ss [b][color=AQUA]([/color][/b]ssget '[b][color=GREEN]([/color][/b][b][color=YELLOW]([/color][/b]0 . "CIRCLE"[b][color=YELLOW])[/color][/b][b][color=GREEN])[/color][/b][b][color=AQUA])[/color][/b][b][color=BLUE])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq i [b][color=BLUE]([/color][/b]sslength ss[b][color=BLUE])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=BLUE]([/color][/b]not [b][color=AQUA]([/color][/b]minusp [b][color=GREEN]([/color][/b]setq i [b][color=YELLOW]([/color][/b]1- i[b][color=YELLOW])[/color][/b][b][color=GREEN])[/color][/b][b][color=AQUA])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]setq en [b][color=AQUA]([/color][/b]ssname ss i[b][color=AQUA])[/color][/b] ed [b][color=AQUA]([/color][/b]entget en[b][color=AQUA])[/color][/b] nd '[b][color=AQUA]([/color][/b][b][color=GREEN]([/color][/b]0 . "POINT"[b][color=GREEN])[/color][/b][b][color=AQUA])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]foreach g '[b][color=AQUA]([/color][/b]6 8 10 39 48 62 210[b][color=AQUA])[/color][/b] [b][color=AQUA]([/color][/b]if [b][color=GREEN]([/color][/b]assoc g ed[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]setq nd [b][color=YELLOW]([/color][/b]cons [b][color=RED]([/color][/b]cons g [b][color=GRAY]([/color][/b]cdr [b][color=#CC00CC]([/color][/b]assoc g ed[b][color=#CC00CC])[/color][/b][b][color=GRAY])[/color][/b][b][color=RED])[/color][/b] nd[b][color=YELLOW])[/color][/b][b][color=GREEN])[/color][/b][b][color=AQUA])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]setq nd [b][color=AQUA]([/color][/b]reverse nd[b][color=AQUA])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]entmake nd[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]entdel en[b][color=BLUE])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]redraw[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] The colors need some tweaking. -David Quote
David Bethel Posted January 1, 2009 Posted January 1, 2009 I think we all missed that group 10 for CIRCLEs are OCS while group 10 for POINTs are WCS AS IS [b][color=BLACK]([/color][/b]defun c:cir2poi [b][color=FUCHSIA]([/color][/b]/ ss i en ed nd[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not ss[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]princ "\nSelect CIRCLEs To Convert To POINTs..."[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq ss [b][color=RED]([/color][/b]ssget '[b][color=BLUE]([/color][/b][b][color=TEAL]([/color][/b]0 . "CIRCLE"[b][color=TEAL])[/color][/b][b][color=BLUE])[/color][/b][b][color=RED])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq i [b][color=NAVY]([/color][/b]sslength ss[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not [b][color=RED]([/color][/b]minusp [b][color=BLUE]([/color][/b]setq i [b][color=TEAL]([/color][/b]1- i[b][color=TEAL])[/color][/b][b][color=BLUE])[/color][/b][b][color=RED])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq en [b][color=RED]([/color][/b]ssname ss i[b][color=RED])[/color][/b] ed [b][color=RED]([/color][/b]entget en[b][color=RED])[/color][/b] nd [b][color=RED]([/color][/b]list [b][color=BLUE]([/color][/b]cons 10 [b][color=TEAL]([/color][/b]trans [b][color=MAROON]([/color][/b]cdr [b][color=OLIVE]([/color][/b]assoc 10 ed[b][color=OLIVE])[/color][/b][b][color=MAROON])[/color][/b] en 0[b][color=TEAL])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 0 "POINT"[b][color=BLUE])[/color][/b][b][color=RED])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]foreach g '[b][color=RED]([/color][/b]6 8 39 48 62 210[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]if [b][color=BLUE]([/color][/b]assoc g ed[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]setq nd [b][color=TEAL]([/color][/b]cons [b][color=MAROON]([/color][/b]cons g [b][color=OLIVE]([/color][/b]cdr [b][color=GRAY]([/color][/b]assoc g ed[b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b][b][color=MAROON])[/color][/b] nd[b][color=TEAL])[/color][/b][b][color=BLUE])[/color][/b][b][color=RED])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]entmake [b][color=RED]([/color][/b]reverse nd[b][color=RED])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]entdel en[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]redraw[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
Lee Mac Posted January 1, 2009 Posted January 1, 2009 David, For starters, nice routine - I like the way you "convert" the circles to points using the DXF references instead of just the inbuilt ACAD point command. But I do have a question: Why do you use "prin1" instead of just "princ" to end your routine? Quote
David Bethel Posted January 1, 2009 Posted January 1, 2009 Lee, AutoLISP is a derivative of Common LISP and I think that the original definition comes from there. From LISP Help as far back as I remember: Used as the last expression in a function, prin1 without arguments results in a blank line printing when the function completes, allowing the function to exit "quietly." After that it is just a habit. -David Quote
Lee Mac Posted January 1, 2009 Posted January 1, 2009 Ahh I see, thanks David. I suppose it is just another variation ~ like terpri that is sometimes used in old LISP routines. I suppose used on their own (princ) and (prin1) don't differ in function, and achieve the same desired clean exit. Thanks for the help. Quote
David Bethel Posted January 2, 2009 Posted January 2, 2009 Something like that. (terpri) is used for screen calls only, whereas (prin__) functions were originally focused on I/O outputs. The big difference in the 2 is that (terpri) returns nil and (princ "\n") returns "\n". Common LISP is a very old computer language, AutoLISP was first introduced in the mid '80. Not much screen usage back in the '50s. -David Quote
big daddy Posted April 9, 2009 Author Posted April 9, 2009 Please excuse my inexperience here but how do I use the code that you so kindly posted here for me. I tried to turn it into a script but that did not seem to work for me. Quote
lpseifert Posted April 9, 2009 Posted April 9, 2009 http://www.cadtutor.net/faq/questions/28/How+do+I+use+an+AutoLISP+routine%3F Quote
