abra-CAD-abra Posted September 28, 2015 Posted September 28, 2015 I have lots of text on a drawing in the following form: "B=12 37 54.1 L=........." Now, since the above string does not contain the degrees (%%d ) minutes (') and seconds (") symbols I am trying to substitute the spaces, as follows: 1st space location: "%%d" 2nd space location: """ 3rd space location: "'" I was looking at using Vl-String-Search, Vl-String-Position and Vl-String-Subst but the spaces may not always be located in the same position - Bump! As always, I appreciate any guidance. Cheers, Quote
Lee Mac Posted September 28, 2015 Posted September 28, 2015 Perhaps something like: (defun foo ( s l ) (if (and l (wcmatch s "* *")) (foo (vl-string-subst (car l) " " s) (cdr l)) s ) ) Or: (defun foo ( s l ) (if l (foo (vl-string-subst (car l) " " s) (cdr l)) s) ) Or: (defun foo ( s l ) (foreach x l (setq s (vl-string-subst x " " s))) ) Example: _$ (foo "B=12 37 54.1 L=........." '("%%d" "\"" "'")) "B=12%%d37\"54.1'L=........." Quote
rlx Posted September 28, 2015 Posted September 28, 2015 Lot of viewers , no thank you's. Not that I think you're losing sleep about it and I centainly don't wanny get sticky , but brilliantly short and effective Lee , as always. Gr Rlx Quote
abra-CAD-abra Posted September 28, 2015 Author Posted September 28, 2015 Thanks Lee, spoilt for choice! Perfect with a capital 'P'... Much appreciated. Quote
Lee Mac Posted September 29, 2015 Posted September 29, 2015 You're most welcome abra-CAD-abra 1 Quote
