profcad Posted September 23, 2015 Share Posted September 23, 2015 We are running Autodesk Building Suite. Both AutoCAD and Revit have the same serial numbers. When I start AutoCAD 2016, it hangs during the processing of checking for Network License. If I load Revit first, then load AutoCAD, it finds the Network License with no hesitation. The problem only happens on my office computer, not the lab or classroom computer. NLM is on a virtual server and has been for years. Any ideal what may be the problem? Quote Link to comment Share on other sites More sharing options...
jammie Posted November 17, 2015 Share Posted November 17, 2015 Hi Is this still an issue? Quote Link to comment Share on other sites More sharing options...
profcad Posted November 18, 2015 Author Share Posted November 18, 2015 Yes I'm still having issues. I just borrowed the licenses since I couldn't find a solution. I will be installing a new computer at the end of the month, so I wasn't going to spend anymore time messing with it. Quote Link to comment Share on other sites More sharing options...
Sengna Posted November 18, 2015 Share Posted November 18, 2015 (edited) Yes I'm still having issues. I just borrowed the licenses since I couldn't find a solution. I will be installing a new computer at the end of the month, so I wasn't going to spend anymore time messing with it. Hi Procad, i used to have the same issue like you had because our autocad licenses were istalled via network not on standalone machine. ex: if the company bought for 10 licenses and everyone in the office are using them, the guy on number 11 has to wait. I ended up borrowed license and returned when i finished. Don't know if anyone have other solution. Edited November 18, 2015 by Sengna Quote Link to comment Share on other sites More sharing options...
jammie Posted November 18, 2015 Share Posted November 18, 2015 First thought on it was a timeout https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Error-A-valid-license-could-not-be-obtained-by-the-network-license-manager.html Second thought was checking that AutoCAD knows the path to the license server https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-specify-license-servers-using-the-ADSKFLEX-LICENSE-FILE-environment-variable-s.html Would also check how lmtools appears under server server status for Revit 2016 and subsequently AutoCAD 2016 for your license server. Version of lmtools should be ok unless you have a distributed license server model and all versions not the same Anyhow, fresh install on a new computer should fix the issue Quote Link to comment Share on other sites More sharing options...
