Dhatsah Posted September 10, 2015 Posted September 10, 2015 Hello I am designing an engagement ring for my soon to be fiancée - I've no real expertise in Inventor (Programmer by trade); However I have managed to thus far to fiddle around with the trial version and draw the basics of the ring, however I am wanting to add some detail and I cannot work out how on earth to do it, so I am hoping someone can help. http://i.imgur.com/QviMutN.png There above is an image of what I have presently - I wanted to put it into the thread but apparently I cannot use spoilers or image size attributes so it would of been too big really for a forum. I want to be able to effectively cut a groove in detail A - however I cannot seem to find a way for inventor to let me sketch onto the extrusion. I then want to add text to the inner band at detail B - the same problem as above occurs. I suppose I could solve the first problem by creating the band in 3 separate parts and assemble them together, but I figure a program as powerful as inventor should probably have a way of doing it. Any pointers or all out this is how you do it would be appreciated. Quote
Lazer Posted September 10, 2015 Posted September 10, 2015 Emboss will do the text and you can do the groove a number of ways, emboss works and so would a simple revolve cut. http://www.cadtutor.net/forum/attachment.php?attachmentid=55503&d=1441913921&thumb=1&stc=1 Quote
Dhatsah Posted September 11, 2015 Author Posted September 11, 2015 Thank you Lazer - I shall check out the link. Thank you again. Quote
