xyao99 Posted September 2, 2015 Share Posted September 2, 2015 Try to accomplish a simple task by lisp: 1. Draw a line from A to B 2. Draw a small circle at A 3. Use command Arraypath 4. Select the circle 5. Select the line as curve 6. Method -> Divide 7. Item -> 5 (could be any number) I do this in autocad and it works all the time no matter how to draw the line and whether the circle is placed at A or B When I use the following lisp, it only works the line is drawn from left to right, or from top to bottom, and the circle is placed at A: (DEFUN C:InsDistributedBar () (command ".LINE" pause pause "") (setq lastline (entlast)) (command ".circle" pause pause "") (setq lastbar (entlast)) (command ".arraypath" lastbar "" lastline 5 "D" "") ) When I replace the arraypath to mimic the direct input for Command Arraypath by the following line: (command ".arraypath" lastbar "" lastline "M" "D" "I" 5 "") The code doesn't work at all. The execution echo is: Command: .arraypath Select objects: 1 found Select objects: Type = Path Associative = Yes Select path curve: Enter number of items along path or [Orientation/Expression] : M Requires an integer between 1 an 32767, or option keyword. Enter number of items along path or [Orientation/Expression] : D Requires an integer between 1 an 32767, or option keyword. Enter number of items along path or [Orientation/Expression] : I Requires an integer between 1 an 32767, or option keyword. Enter number of items along path or [Orientation/Expression] : 5 Specify the distance between items along path or [Divide/Total/Expression]: Select grip to edit array or [ASsociative/Method/Base point/Tangent direction/Items/Rows/Levels/Align items/Z direction/eXit]: nil I don't know that much about lisp. I don't know what is wrong. Please help. Thanks. Xiaoping Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted September 2, 2015 Share Posted September 2, 2015 Try this (DEFUN C:InsDistributedBar () (command ".LINE" pause pause "") (setq lastline (entlast)) (command ".circle" pause pause) (setq lastbar (entlast)) (command "arraypath" lastbar "" lastline 5 "D" "M" "D" "") (princ) ) (command "arraypath" lastbar "" lastline [b][color="red"]5 "D" "M" "D" ""[/color][/b]) Does the same thing which you were trying for but with little variation... If you can give Divide option in your code itself then why are you trying for Method->Divide Quote Link to comment Share on other sites More sharing options...
xyao99 Posted September 2, 2015 Author Share Posted September 2, 2015 The reason I was trying (command ".arraypath" lastbar "" lastline "M" "D" "I" 5 "") is to mimic the way you would direct use Arraypath in autocad. I tried your code (command "arraypath" lastbar "" lastline 5 "D" "M" "D" "") It still doens't work. Tried to draw the line in different ways and sometimes the 5 circles could be placed in the opposit direction. Thanks. Xiaoping Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted September 2, 2015 Share Posted September 2, 2015 Ohh Sorry didnt check that Try this now : (defun c:test (/ a b l c) (if (setq a (getpoint "\nSpecify start point : ") b (getpoint a "\nSpecify end point : ") ) (progn (command ".line" a b "") (setq l (entlast)) (command ".circle" a pause) (setq c (entlast)) (command ".arraypath" c "" l "O" a b "E" 5 "D" "X") ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
xyao99 Posted September 2, 2015 Author Share Posted September 2, 2015 Trie your code, works perfect! Thanks a lot! Although I don't understand where the "O" option is from. Where can I get the document as how to use the command in lisp? (syntax, arguments, ...). Xiaoping Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted September 2, 2015 Share Posted September 2, 2015 Trie your code, works perfect! Thanks a lot! Xiaoping Glad to here that Although I don't understand where the "O" option is from. "O" stands for Orientation.... You can see that in commandline Where can I get the document as how to use the command in lisp? (syntax, arguments, ...). Xiaoping There are websites available where you learn lisp... e.g. http://www.afralisp.net/index.php http://lee-mac.com/index.html Quote Link to comment Share on other sites More sharing options...
xyao99 Posted September 2, 2015 Author Share Posted September 2, 2015 I checked autocad 2015 command line and don't see Orientation option. I also checked the arraypath document and don't see this option either. http://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-D36C46CD-4E17-4A16-A387-C0B158EA5A9E-htm.html Would you please show me where you get this option? Thanks. Xiaoping Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted September 2, 2015 Share Posted September 2, 2015 This example is taken from your 1st post... See red highlight Command: .arraypath Select objects: 1 found Select objects: Type = Path Associative = Yes Select path curve: Enter number of items along path or [[color="red"]Orientation[/color]/Expression] <[color="red"]Orientation[/color]>: M Requires an integer between 1 an 32767, or option keyword. Quote Link to comment Share on other sites More sharing options...
xyao99 Posted September 2, 2015 Author Share Posted September 2, 2015 That one was the echo from the arraypath executed from the code. If you use arraypath command directly in autocad command line, you don't get that Orientation option. It seems that when you use the command directly, the options and arguments provided/required are different from the one executed within lisp (command ".." ...). It doesn't make sense. Where are these documented? Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted September 2, 2015 Share Posted September 2, 2015 You are absolutely right. I have noticed that. M also 1st time came across such things. Normally command executes in same manner from Manual and automatic operation in autocad. I don't think there will any documentary on this. I would be interested if it is available. In such scenario experience n practice comes into picture. Quote Link to comment Share on other sites More sharing options...
HFBandit Posted December 20, 2016 Share Posted December 20, 2016 That one was the echo from the arraypath executed from the code. If you use arraypath command directly in autocad command line, you don't get that Orientation option. It seems that when you use the command directly, the options and arguments provided/required are different from the one executed within lisp (command ".." ...). It doesn't make sense. Where are these documented? If I execute ARRAYPATH manually (command line), then it works how I want it to, but if I try to make it a script or macro (I'm using LT), the options are totally different and it doesn't work. What is the logic behind this and how do I work around it? There is a need in our office for us to do an array along a centreline on a pretty regular basis, so it would be better to have a button to press rather than having to manually type all the options in every time. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 20, 2016 Share Posted December 20, 2016 Removed wrong idea Quote Link to comment Share on other sites More sharing options...
roop Posted January 12 Share Posted January 12 Can we use trim command in autolisp. IF I want trim some particular coodinate points means how to do that,Can u pls send me a sample code for trim command Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 13 Share Posted January 13 (edited) Just write down what you do now manually, that is the basics of your lisp code. The steps have to be in lisp code format. You can use Logfileon to record the manual steps, logfileoff to turn off logfile, the Log file is stored in your temporary directory path, look at Options, FIle, temporary path for location. Edited January 13 by BIGAL 1 1 Quote Link to comment Share on other sites More sharing options...
