I'm trying to modify Title Block Attributes values using -attedit without being prompted for old value of the attribute. The only way I was able to make it work is as shown below if I specify old value (100). I'm trying to write an external script (.scr) which will be specified upon draftsight.exe startup, open the drawing, modify title block attributes, save and exit without human interaction. The script does not know the old value, that's why i'm trying to avoid it. I'm using draftsight.
: -EDITBLOCKATTRIBUTE Default: Yes
Confirm: Edit block attributes one at a time?
Specify Yes or No» n
Performing global editing of block attribute values.
Default: Yes
Confirm: Edit only attributes currently visible?
Default: *
Options: * to select all blocks or
Specify block(s)» MY_TTL_BLK5
Default: *
Options: * to select all attributes or
Specify attribute name(s)» DRAWINGNO
Default: *
Options: * to select all attribute values or
Specify attribute value» 100
1 block attributes selected.
Specify old text string» 100
Specify new text string» 101
Thank you.
