Jwagner Posted August 21, 2015 Posted August 21, 2015 I have always been able to create a custom palette for a specific project and drag and drop assemblies to use in various drawings. As of recently, I have been able to drag and drop assemblies to a custom palette but they will not pull into drawings. Through research I have found that assemblies placed in a custom palette are stored here C:\ProgramData\Autodesk\C3D 2014\enu\Assemblies. The assemblies that I am adding to a custom palette are no longer being stored in the above location. How do I direct Civil 3d to again store my assemblies in the custom palette to the folder listed above? Quote
BlackBox Posted August 21, 2015 Posted August 21, 2015 Welcome to CADTutor. What are your Palette settings in Options, File tab? Cheers Quote
Jwagner Posted August 21, 2015 Author Posted August 21, 2015 Under Tool Palettes File Locations, it directs to these locations: C:\Users\jwagner\AppData\Roaming\Autodesk\C3D 2014\enu\support\toolpalette C:\custom\autocad\common\toolpallete Quote
