BrianTFC Posted August 21, 2015 Share Posted August 21, 2015 I was wondering if there is a lisp routine out the will scale a block down to fit inside of box? I would work on the same as the Textfit lisp but with blocks. its sounds simple but I have know clue where to start. step 1 = select block step 2 = select inside side of interior area of box. if someone could help I would really appreciate it. Thanks, Brian Quote Link to comment Share on other sites More sharing options...
EBROWN Posted August 21, 2015 Share Posted August 21, 2015 Use a table and insert the block into the cell. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 22, 2015 Share Posted August 22, 2015 Ebrown ?? Anyway search for bounding box routine this will work out the size of your block then it would be pretty simple to work out the new scale. I know it exists hopefully does work for blocks. Quote Link to comment Share on other sites More sharing options...
BrianTFC Posted August 24, 2015 Author Share Posted August 24, 2015 Thanks BIGAL I'll Do that.... Quote Link to comment Share on other sites More sharing options...
