Running Autocad 2000 on Windows 10
Stanier
Hi - I understand that a 32-bit version of Windows 10 is to be made available alongside the 64-bit version. Does this mean that I would be able to ditch my old Windows XP based system and continue to run AutoCad 2000 on the new 32-bit Windows 10? - Kind regard
If your old Autocad 2000 version is working fine on your XP system, then I would stick with that. Windows 10 may have a 32 bit version, but it's a brand new operating system and from what I've seen around here with people trying to run really old software on a new OS, you will have nothing but problems. So, if it were me, I would stick with what's working.
Unless there is an absolute need to keep using 2000, you may also want to consider updating your software. Even the free CAD options these days would be an improvement.
I still have, and still use, 2000i but keep it on an old machine that runs Windows 98SE. Not internet connected of course.
I would expect to have problems trying to run 2000 on Win10.
If your 2000 runs on XP then keep it there.
Avoid connecting XP or older systems to the web, it is a security risk.
If you need to transfer files to or from an old OS its best to put them on a memory stick and plug this into a newer machine to do the transfer.
  • 8 years later...
  • 6 months later...
autocad lt 2000i runs perfectly on windows 10
  • 2 weeks later...
Hi there,
Yes, Windows 10 does have a 32-bit version available, so you should be able to install it and continue running your old software like AutoCAD 2000. However, keep in mind that older programs might not run as smoothly on newer systems, so you might encounter some compatibility issues. It’s always a good idea to test it out first before fully switching over.
Given this topic was started 2015 and now up to Win 11 it may be better to look at upgrading software to 64bit, Bricscad is a good alternative to Autocad and is perpetual.
Windows 10 64-bit, I do not have the acetutil functions from Express tools working, but so far most Express tools seem to work.
Windows 11 may be different.
Correct BIGAL, should just get an alternate, though for as little as I do at home right now, 2000i is just fine.
Probably will get BricsCAD when I get a new computer here soon.
