Text along polyline export length, distance, coordinate.
Hay, please any thing give lisp or please other separatlly lisp available fine.
Hi ,
Here is a draft codes for this process , so test this routine and let me know if you need any modification or so.
(defun c:test (/ f o s e lst p1 pt ang v l p _mt _t _parse)
 ;; Tharwat 16.08.2015		;;
 (if (and (setq f (getfiled "Select Excel file :"
                            (getvar 'dwgprefix)
                            "csv"
                            16
          (setq o (open f "r"))
          (princ "\nSelect LWpolyline :")
          (setq s (ssget "_+.:S:E" '((0 . "LWPOLYLINE"))))
     (defun _mt (pt str)
       (entmakex (list '(0 . "MTEXT")
                       '(100 . "AcDbEntity")
                       '(100 . "AcDbMText")
                       '(40 . 0.6)
                       '(8 . "point")
                       (cons 10 pt)
                       (cons 1 str)
                       (cons 7
                             (if (tblsearch "STYLE" "STANDARD")
                               "STANDARD"
                               (getvar 'textstyle)
     (defun _t (pt str)
       (entmakex (list '(0 . "TEXT")
                       '(8 . "Structure")
                       (cons 10 pt)
                       (cons 11 pt)
                       (cons 1 str)
                       (cons 7
                             (if (tblsearch "STYLE" "ARIAL-N")
                               "ARIAL-N"
                               (getvar 'textstyle)
                       '(8 . "Structure")
                       '(40 . 2.0)
                       '(50 . 0.0)
                       ;; '(71 . 0)
                       ;; '(72 . 1)
                       ;; '(73 . 2)
     (defun _parse (string delimiter / pos lst)
       (while (setq pos (vl-string-search delimiter string 0))
         (progn (setq lst (cons (substr string 1 pos) lst))
                (setq string (substr string (+ pos 2) (strlen string)))
       (if (and string (/= string ""))
         (setq lst (cons string lst))
       (setq lst (reverse lst))
     (setq e (ssname s 0)
           l (vlax-curve-getdistatpoint e (vlax-curve-getendpoint e))
           p (vlax-curve-getstartpoint e)
     (read-line o)
     (while (setq v (read-line o))
       (setq lst (_parse v ","))
       (if (< (read (nth 5 lst)) l)
           (setq pt  (vlax-curve-getpointatdist e (read (nth 5 lst)))
                 ang (angle '(0. 0. 0.)
                            (vlax-curve-getfirstderiv
                              e
                              (vlax-curve-getparamatpoint e pt)
                 p1  (polar pt
                            ((eval (if (eq (last lst) "Right")
                              ang
                              (* pi 1.5)
                            (read (nth 4 lst))
           (entmake (list '(0 . "LINE")
                          (cons 10 pt)
                          (cons 11 p1)
                          (cons 8 "perp")
           (entmake (list '(0 . "POINT")
                          (cons 10 p1)
                          '(62 . 256)
                          (assoc 8 (entget e))
           (_mt (list (car p1) (cadr p1) (read (nth 3 lst)))
                (nth 4 lst)
           (_t p1 (car lst))
     (close o)
 )(vl-load-com)
Tharwat,
Thank you very much to the reply, but i want autocad to csv report.
  sanju2323 said:
Tharwat,
I make it on the contrary ? :lol:
Your first post wasn't clear enough to tell that you want it to excel and not from excel to cad. !
sorry for confusion, Yes, I want the opposite (answer) lisp. 600km DWG file data already plotted. So I needed to export data as per my attachment csv requirement.
Edited by sanju2323
