vernonlee Posted August 5, 2015 Author Posted August 5, 2015 A further option the 100+ do they have title blocks ? If so just enter title block description like sheet 24 you can locate the title block that matches lsp and then zoom a point and a scale. Hi BIGAL. Not sure what you mean. I mainly use the macro script in the model space to "amend" the drawing. My title block is in paperspace, which i mostly not touching. Quote
BIGAL Posted August 5, 2015 Posted August 5, 2015 You referred to 100+ dwgs but what you meant was 100+ grouped objects. Again put a non plotting block in the middle of the group with one attribute say sheet num, then you could just do a jump to sheet with number. (jump 23 100) jump a defun, 23 sheet or view pt, 100 is scale. Its short enough to type or use the 2 line version of my multi line dcl that I posted recently. If you want to go this way just post name of block and attribute tag name. Quote
vernonlee Posted August 5, 2015 Author Posted August 5, 2015 You referred to 100+ dwgs but what you meant was 100+ grouped objects. Again put a non plotting block in the middle of the group with one attribute say sheet num, then you could just do a jump to sheet with number. (jump 23 100) jump a defun, 23 sheet or view pt, 100 is scale. Its short enough to type or use the 2 line version of my multi line dcl that I posted recently. If you want to go this way just post name of block and attribute tag name. It's hundred individual drawing files, not group objects. It has nothing to do with title block. The macro script ONLY helps me to zoom straight to the view area concern. Quote
