RobDraw Posted July 30, 2015 Share Posted July 30, 2015 Maybe this is a language thing but we have already discussed the methodology. Can you describe how your model is set-up? Single user, central file, using links, etc. Also, please describe what exactly is wrong with what you are getting. Hopefully someone more knowledgeable about the civil aspect can be of more assistance than I can. Plus, I probably won't be around much until Monday. Quote Link to comment Share on other sites More sharing options...
halam Posted July 30, 2015 Author Share Posted July 30, 2015 What does it matter of it is central or not? Do You understand what i want and the problems i have with these options? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 30, 2015 Share Posted July 30, 2015 No I don't understand. Why do you think I keep asking? I'm trying to understand and I'm not going to do any more testing unless you are more forthcoming with information. Sometimes. you need to help others help you. I did explain that I am not well versed in Civil, so you need to provide more information for me unless someone else, more knowledgeable, starts helping. Quote Link to comment Share on other sites More sharing options...
halam Posted July 30, 2015 Author Share Posted July 30, 2015 Read the first post please... Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 30, 2015 Share Posted July 30, 2015 What part of "I don't understand" didn't you understand? If you are not going to provide a better description, I'm done here. I don't want to run tests without knowing the correct circumstances. Good luck. Quote Link to comment Share on other sites More sharing options...
halam Posted July 30, 2015 Author Share Posted July 30, 2015 What is it you do not understand rob? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 30, 2015 Share Posted July 30, 2015 You already said I don't need any more information. I cannot help you with the given information so maybe someone will be able to. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 30, 2015 Share Posted July 30, 2015 must lost my password along the way I now remember. Using differentt machines. I don't mind if you just delete one of me ..;-) I would like to get get back to the topic if this is still possible. Drawings as revit output is still impotent stuff after all! Export to separate Xrefs I tried but did not make much difference. To me it just seems that the checkboxes just do not work as they are intended (that is, views together in a sheets, options?) Would like confirmation about this defect or sincerely would like the right workaround.. Any other suggestions what I should try? Thanks for the screenshots. I will test on one of my existing projects and report back to you. Quote Link to comment Share on other sites More sharing options...
halam Posted July 30, 2015 Author Share Posted July 30, 2015 Thanks for your effort! Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 3, 2015 Share Posted August 3, 2015 Did this get tested? Quote Link to comment Share on other sites More sharing options...
halam Posted August 3, 2015 Author Share Posted August 3, 2015 There are export buttons that gets you sheets to dwg. Do you, like me, encounter loss of coordinates in dwg you work out design in (GIs) coordinats. (shared coordinats in rvt)? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted August 3, 2015 Share Posted August 3, 2015 Did this get tested? I am in the field right now and have not had a chance to test since being away from my computer. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 3, 2015 Share Posted August 3, 2015 Just curious as to how it works out. Quote Link to comment Share on other sites More sharing options...
hlammerts Posted August 25, 2015 Share Posted August 25, 2015 Me too, did you get it done to export dwg sheets right? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 25, 2015 Share Posted August 25, 2015 Alright, I'm going to try this one more time as knowing a bit more about this might help me. My thought was that maybe you could do the export and massage the results in AutoCAD a bit to get what you want. In order to see if that works, I need to know what I'm working with. Even if the details seem minor, it would help me to understand what you want for an end result. It might take a step or two more than the export from Revit if that doesn't do exactly what you want. Knowing how your project is set-up is just the first step. There are a lot of variables in project set-up and some of them may affect your desired result. If you are expecting a one step solution, you might be expecting too much. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted August 26, 2015 Share Posted August 26, 2015 I exported Sheets, both with XREF and no XREF, and in Model Space as I suspected the origin is exactly where it should be. Click the image below to enlarge: Tested and confirmed on my end. The image shows Area's A, B, C and D, but notice the correlation of the UCS between each drawing. They are all in the correct spot as the 0,0 WCS, which is the intersection of gridlines A,1. Hope this helps in ruling out possibilities at least. -TZ Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 26, 2015 Share Posted August 26, 2015 No offense, but that was a long wait for an anticlimactic ending. It works as one would expect. I'm wondering what the OP is doing differently. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted August 26, 2015 Share Posted August 26, 2015 Haha, that was a long wait indeed. I've been in the field performing 3D laser scans on a large building so the past few weeks has been practically zero time in front of Revit. Quote Link to comment Share on other sites More sharing options...
halam Posted August 26, 2015 Author Share Posted August 26, 2015 It is about exporting shared coordinats guys. I Guess i did not Write that but This is the method to model in coordinats. I haven't had the opportunity to get back to my laptop. Will post some example of the issue later.. Quote Link to comment Share on other sites More sharing options...
halam Posted September 2, 2015 Author Share Posted September 2, 2015 I thought it would be wise to furthermore share and discuss this on the Autodesk forum. More details, sample files RVT and DWG, here . http://forums.autodesk.com/t5/revit-structure/dwg-sheet-to-coordinats/m-p/5800647#M13270 By the way, it is this nice bridge in the Netherlands I use as sample data http://static-dc.autodesk.net/content/dam/autodesk/www/industries/civil-infrastructure/rail-infrastructure/Docs/adsk_customer-story_Breijn_Linge-RR-bridge_NE_letter_en.pdf Quote Link to comment Share on other sites More sharing options...
