akira2k1 Posted July 17, 2015 Posted July 17, 2015 Sorry I'm pretty new to Xdata, Xrecords & dictionaries and I got some code from "AfraLisp website and I'm trying to modify it to work for what i need. I'm going to store multiple "Part" dictionary information in Xrecords. Then I want to append these dictionaries to an entity (below only shows one dictionary, but in the future I will have "PartL1, PartL2, PartL3" that will all be applied to one entity). Then down the road I will make a lisp that will change the values for the "PartNum" "QTY" & "Spacing" for each. The problem is I can't get the Xrecord dictionary to append to the entity's dictionary. Everything works fine until I get to this line of code: (dictadd ent "PartL1" adict) I don't know if i have the formating correct or I'm referencing this incorrectly. Please help, i've done research and I can't get past this. (defun c:applyassem (/ vars varlist) ;;retrieve XRecord "PartL1" from dictionary "WSI_DICT" ;;which in turn calls both functions below (setq vars (get-or-make-Xrecord)) ;;get dictionary were "PartL1" is stored (setq adict (cdr (car (dictsearch (namedobjdict) "WSI_DICT")))) ;;get entity to app (setq ent (car (entsel))) (dictadd ent "PartL1" adict) (princ) ) (defun get-or-create-Dict (/ adict) ;;test if "WSI_DICT" is already present in the main dictionary (if (not (setq adict (dictsearch (namedobjdict) "WSI_DICT"))) ;;if not present then create a new one and set the main dictionary as owner (progn (setq adict (entmakex '((0 . "DICTIONARY")(100 . "AcDbDictionary")))) ;;if succesfully created, add it to the main dictionary (if adict (setq adict (dictadd (namedobjdict) "WSI_DICT" adict))) ) ;;if present then just return its entity name (setq adict (cdr (assoc -1 adict))) ) );defun (defun get-or-make-Xrecord(/ adict anXrec) (cond ;;first get our dictionary. make here in case it doesn't exit ((setq adict (get-or-create-Dict)) (cond ;;if "WSI_DICT" is now valid then look for "PartL1" Xrecord ((not (setq anXrec (dictsearch adict "PartL1"))) ;;if "PartL1" was not found then create it (setq anXrec (entmakex '((0 . "XRECORD") (100 . "AcDbXrecord") (7 . "PART#") ;will be part number (90 . 1) ;will be default qty of part (91 . 16) ;will be spacing in inches ) );entmakex );setq anXrec ;;if creation succeeded then add it to our dictionary (if anXrec (setq anXrec (dictadd adict "PartL1" anXrec))) );not ;;if it's already present then just return its entity name (setq anXrec (cdr (assoc -1(dictsearch adict "PartL1"))) );setq anxrex );cond );setq adict );cond );defun Quote
akira2k1 Posted July 17, 2015 Author Posted July 17, 2015 Or to make it simpler, how can I get this code to work: (defun c:assemapply (/ ent xname datalist) (setq ent (car (entsel))) (setq datalist (append (list '(0 . "XRECORD") '(100 . "AcDbXrecord")) '((1 . "PartL1") (7 . "PART#") (90 . 1) (91 . 16)))) (setq xname (entmakex datalist)) (dictadd ent "PartL1" xname) );defun Quote
