wimal Posted July 15, 2015 Posted July 15, 2015 When I try to create ceiling or floor after selecting walls the command does not exit.It always requesting to select a wall. Quote
RobDraw Posted July 15, 2015 Posted July 15, 2015 (edited) That is right. If you are having trouble exiting the command, I would suggest you watch a couple tutorialS to get you rolling but you will probably need some formal training. Revit is not easy. Edited July 15, 2015 by RobDraw Quote
tzframpton Posted July 15, 2015 Posted July 15, 2015 When I try to create ceiling or floor after selecting walls the command does not exit.It always requesting to select a wall. Steve Stafford explains this subtle Revit quirk back in 2009: http://revitoped.blogspot.com/2009/10/four-ways-to-stop-waitpause.html Hope this helps. -TZ Quote
wimal Posted July 16, 2015 Author Posted July 16, 2015 That is right. If you are having trouble exiting the command, I would suggest you watch a couple tutorialS to get you rolling but you will probably need some formal training. Revit is not easy. Yes Stilling I am learning. The ceiling problem solved. The problem was I have not selected correct ceiling type & correct offset distance from the floor. Now I am trying to draw floors. Thanks for your advice. Quote
RobDraw Posted July 16, 2015 Posted July 16, 2015 Then, I totally did not understand your first post. Quote
tzframpton Posted July 16, 2015 Posted July 16, 2015 Then, I totally did not understand your first post.Apparently I didn't either!! That makes two of us. Glad he got it sorted out. Quote
