Sandervp Posted July 15, 2015 Posted July 15, 2015 (edited) Hello everybody! If I want to use the "extrim" command, I do select a line first and after this I click on side next to the line. After that, AutoCad does, first, zooms in very, very slow to the line I'd selected. Second, he trims all the lines next to the selected line, on the side I've chosen. Finally, AutoCad zooms out very, very slow........... Sometimes it takes 30 seconds or something for extrim a couple of lines. I'm using AutoCad 2015 at this moment. I had also used older versions. Some versions also had this problem but in some versions it went very fast! Zoom in, extrim and zoom out were done in 1 second. Anybody knows how I can solve this? (variables Edgemode=0 and Projmode=1) example extrim.dwgFetching info... Edited July 15, 2015 by Sandervp insert example Quote
ReMark Posted July 15, 2015 Posted July 15, 2015 Attach a copy of the drawing to your next post. Someone will test it on their system to see if they experience the same problem. Quote
Sandervp Posted July 15, 2015 Author Posted July 15, 2015 ReMark said: Attach a copy of the drawing to your next post. Someone will test it on their system to see if they experience the same problem. Example attached Quote
ReMark Posted July 15, 2015 Posted July 15, 2015 I fully expected a copy of the actual drawing not an example. But.................... No problem here. Probably took about a tenth of a second to complete the task. Quote
Sandervp Posted July 15, 2015 Author Posted July 15, 2015 ReMark said: I fully expected a copy of the actual drawing not an example. But.................... No problem here. Probably took about a tenth of a second to complete the task. If I use the extrim command in this example drawing (size 33.5kb), it tooks 10 seconds already before AutoCad was finished. The bigger the drawing, the longer it takes. Quote
ReMark Posted July 15, 2015 Posted July 15, 2015 (edited) Maybe you have an under-performing system. Addendum: I opened your drawing a second time and arrayed the horizontal lines nine additional times and stretched the one vertical (trimming) line. Then I ran the EXTRIM command. Practically the same result. The command executed in barely the blink of an eye. I then doubled the number of lines (close to 200), ran the command and attained similar results. Edited July 15, 2015 by ReMark Quote
SLW210 Posted July 15, 2015 Posted July 15, 2015 Maybe you can post your computer specifications? Are you working on a network? Quote
Sandervp Posted July 15, 2015 Author Posted July 15, 2015 SLW210 said: Maybe you can post your computer specifications? Are you working on a network? Computer specifactions: Windows 7 SP1 Intel® Xeon® CPU E3-1220 v3 @ 3.10 GHz RAM 16 GB System 64-bit Yes I am working on a network. Quote
ReMark Posted July 15, 2015 Posted July 15, 2015 My computer specs are not as good as yours yet I have no problem. Strange. Quote
