Using edit system I can change system color of pipe . But cant change the system color of duct. How can I change color of the duct.
One of two ways: You can apply a Filter to the View that assigns the selected color to the Duct, Duct Fittings, Duct Accessories and Mechanical Equipment, so as long as the Categories and Search Criteria of the Filter is properly set. The Filter will need to be set to Solid Fill under Projection/Surface Patterns Override in the Filters tab of Visibility/Graphics.
Another way, which is my preferred way but *not* the orthodox way of doing things, is to apply a Material to the System itself, assigning the selected color of the Material to the entire System.
Hope this helps. 8)
-TZ
