XML file problem with Web Map Service (WMS)
I want to transfer a WMS to xml file, but I don't know how to write the xml file.
I just copy from a sample xml, and changed something inside, but it doesn't work.
There are some possible cause:
The WMS version is 1.3.0, if I change the version in the xml, it will fail to load in the beginning.
I am not sure about the Image Format of the WMS, maybe it is not image/jpeg.
I saw some sample use in the 20037508.34 DataWindow, and I used the 180 and 90.
1.1.1
http://xxxxxxxxxxxxxxxxxxxxx/wms?
EPSG:4326
image/jpeg
Imagery
DateOrEarlier
108
-10
155
-45
65400200
56282900
xxxxxxxxx:xxxxxxxxxxx
