Tharwat Posted June 26, 2015 Posted June 26, 2015 You did not follow any of my replies to you in this thread at all . There are lots of mistakes and needed codes to add to make it to work. why is that ? Quote
CafeJr Posted June 26, 2015 Author Posted June 26, 2015 Tharwat said: You did not follow any of my replies to you in this thread at all . There are lots of mistakes and needed codes to add to make it to work. why is that ? I had wrote your previows code Tharwat!... But I did some changes only to test the items... to try to find the error... You can see that the defun showimage is there yet!... I'm sure that there has a lot of mistakes... he he he... It is a work from a Beginner!... I'll use this code to insert these blocks as a standard in electrical drawings!... Quote
Tharwat Posted June 26, 2015 Posted June 26, 2015 Hi, What is the use of the two toggles Sobe and Desce ? And also the popup_list ? Quote
Tharwat Posted June 28, 2015 Posted June 28, 2015 (edited) Here is the main principle of writing the codes to toggle radio buttons with slide files so just continue with the rest of radio buttons as shown in the following example. NOTE: Don't forget to localize the variable 'files' . You have a few mistakes in the dcl file , so correct them as following : is_enable = true ; [color=red]MUST BE[/color] is_enabled = true ; key = img; [color=red]MUST BE[/color] key = "img"; Edited June 28, 2015 by Tharwat Quote
Tharwat Posted June 28, 2015 Posted June 28, 2015 Here I am posting alone , anyway try this complete one and let me know . NOTE: Please arrange the name of files and add if any file name is missing to not in its correct place . [ UNTESTED ] (defun c:deti (/ dcl_id tipo bitola bitolas sobe desce userclick showimage files) ;;; Modified by Tharwat 28.06.2015 ;; (if (and (< 0 (setq dcl_id (load_dialog "Deti.dcl"))) (new_dialog "Deti" dcl_id) ) (progn (defun showimage (file / a b) (start_image "img") (fill_image 0 0 (setq a (dimx_tile "img")) (setq b (dimy_tile "img")) 0 ) (slide_image 0 0 a b file) (end_image) ) (setq bitola "3/4\"" bitolas '("1/2\"" "3/4\"" "1\"" "1.1/2\"" "2\"" "2.1/2\"" "3\"" "4\"" ) sobe 0 desce 0 files '("C:\\Lisp\\Desenvolvimento\\Slides\\slide-C.sld" "C:\\Lisp\\Desenvolvimento\\Slides\\slide-E.sld" "C:\\Lisp\\Desenvolvimento\\Slides\\slide-X.sld" "C:\\Lisp\\Desenvolvimento\\Slides\\slide-LB.sld" "C:\\Lisp\\Desenvolvimento\\Slides\\slide-LL.sld" "C:\\Lisp\\Desenvolvimento\\Slides\\slide-LR.sld" "C:\\Lisp\\Desenvolvimento\\Slides\\slide-T.sld" "C:\\Lisp\\Desenvolvimento\\Slides\\slide-BR.sld" "C:\\Lisp\\Desenvolvimento\\Slides\\slide.sld" ) ) (start_image "im") (fill_image 0 0 (dimx_tile "im") (dimy_tile "im") 5) (end_image) (start_list "Bitolas") (mapcar 'add_list bitolas) (end_list) (showimage "C:\\Lisp\\Desenvolvimento\\Slides\\slide-C.sld") (action_tile "rb1" "(setq tipo \"C\")(mode_tile \"tog1\" 1)(mode_tile \"tog2\" 1)(showimage (car files))" ) (action_tile "rb2" "(setq tipo \"E\")(mode_tile \"tog1\" 1)(mode_tile \"tog2\" 1) (showimage (cadr files))" ) (action_tile "rb3" "(setq tipo \"LB\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0)(showimage (caddr files))" ) (action_tile "rb4" "(setq tipo \"LL\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0) (showimage (nth 3 files))" ) (action_tile "rb5" "(setq tipo \"LR\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0)(showimage (nth 4 files))" ) (action_tile "rb6" "(setq tipo \"T\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0)(showimage (nth 5 files))" ) (action_tile "rb7" "(setq tipo \"X\")(mode_tile \"tog1\" 1)(mode_tile \"tog2\" 1)(showimage (nth 6 files))" ) (action_tile "rb8" "(setq tipo \"BR\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0)(showimage (nth 7 files))" ) (action_tile "rb9" "(setq tipo \"LUR\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0)(showimage (nth 8 files))" ) (action_tile "cancel" "(done_dialog)") (action_tile "accept" "(setq userclick t Sobe (atoi $value) Desce (atoi $value) Bitola (atof (get_tile \"Bitolas\"))) (done_dialog)" ) (start_dialog) (unload_dialog dcl_id) ) (if (< 0 dcl_id) (unload_dialog dcl_id) ) ) (if userclick (if (and (= desce 1) (= sobe 1)) (alert "ERRO: Selecione apenas Sobe ou Desce!") (progn (setq bitola (nth (fix bitola) bitolas)) (if (= sobe 1) (setq blockname (strcat tipo "-S" (if (= tipo "BR") " - Bucha de Redução Sobe" (if (= tipo "LUR") " - Luva de redução Sobe" " - Condulete" ) ) ) ) (if (= desce 1) (setq blockname (strcat tipo "-D" (if (= tipo "BR") " - Bucha de Redução Desce" (if (= tipo "LUR") " - Luva de redução Desce" " - Condulete" ) ) ) ) (setq blockname (strcat tipo (if (= tipo "BR") " - Bucha de redução" (if (= tipo "LUR") " - Luva de redução" " - Condulete" ) ) ) ) ) ) (command "_.-Insert" blockname "\\" 1. 1. 0. (strcat tipo "-%%C" bitola) ) ) ) ) (princ) ) Quote
CafeJr Posted June 29, 2015 Author Posted June 29, 2015 Tharwat said: Here I am posting alone , anyway try this complete one and let me know . ... Tharwat!... I have no words to show you how I'm grateful to your support and help!... Sorry about delay to answer you, but I was so far from the computer this weekend!... Quote
Tharwat Posted June 29, 2015 Posted June 29, 2015 CafeJr said: Tharwat!... I have no words to show you how I'm grateful to your support and help!... Sorry about delay to answer you, but I was so far from the computer this weekend!... Nice, you are most welcome Did you get it solved as you expected ? Quote
CafeJr Posted June 29, 2015 Author Posted June 29, 2015 Tharwat said: Here is the main principle of writing the codes to toggle radio buttons with slide files so just continue with the rest of radio buttons as shown in the following example. NOTE: Don't forget to localize the variable 'files' . You have a few mistakes in the dcl file , so correct them as following : is_enable = true ; [color=red]MUST BE[/color] is_enabled = true ; key = img; [color=red]MUST BE[/color] key = "img"; Done!... Thanks to your correction!... Quote
CafeJr Posted June 29, 2015 Author Posted June 29, 2015 Tharwat said: Hi, What is the use of the two toggles Sobe and Desce ? And also the popup_list ? Only to answer you!... The two toggles are to select a variation of some blocks, some of them could be to up (sobe) or down (desce), from the level where it is inserted the block. The popup_lis is only a way to represent the diameter that shall to be filled the attribute field property. Quote
CafeJr Posted June 29, 2015 Author Posted June 29, 2015 (edited) Error - Double post... Edited June 29, 2015 by CafeJr Quote
CafeJr Posted June 29, 2015 Author Posted June 29, 2015 (edited) Tharwat said: Nice, you are most welcome Did you get it solved as you expected ? Yes, I'm studying the code right now to try to learn something there!... He he he... The images are now working!... The code are running until to the check toggles (up and down) and stop!... I'm trying to fix it!... He he he... Edited June 29, 2015 by CafeJr Quote
Tharwat Posted June 29, 2015 Posted June 29, 2015 CafeJr said: Yes, I'm studying the code right now to try to learn something there!... He he he... The images are now working!... The code are running until to the check toggles (up and down) and stop!... I'm trying to fix it!... He he he... Just feel free to ask if you have any question. Quote
CafeJr Posted June 29, 2015 Author Posted June 29, 2015 Tharwat said: Just feel free to ask if you have any question. Tharwat, The first objective from this Thread was to learn how work with radio_button and image linking it! I got it!... Thanks again!... About the code, I'm debugging it and (I don't know why) after the OK (accept) the variables Sobe and Desce it is filled up with 1, has no where to the code write it!... I was using: (action_tile "tog1" "(setq Sobe (atoi $value))") (action_tile "tog2" "(setq Desce (atoi $value))") You changed it to: (action_tile "accept" "(setq userclick t Sobe (atoi $value) Desce (atoi $value) Bitola (atof (get_tile \"Bitolas\"))) (done_dialog)" ) I change it back and now it works... Quote
Tharwat Posted June 29, 2015 Posted June 29, 2015 CafeJr said: (action_tile "accept" "(setq userclick t Sobe (atoi $value) Desce (atoi $value) Bitola (atof (get_tile \"Bitolas\"))) (done_dialog)" ) I change it back and now it works... Replace my above modification to the following and try again. (action_tile "accept" "(setq userclick t Sobe (atoi (get_tile \"tog1\")) Desce (atoi (get_tile \"tog2\")) Bitola (atof (get_tile \"Bitolas\"))) (done_dialog)") Quote
CafeJr Posted June 29, 2015 Author Posted June 29, 2015 Tharwat, It's it!... Now it works!!!... Thanks again to your support!... Quote
Tharwat Posted June 29, 2015 Posted June 29, 2015 CafeJr said: Thanks again to your support!... Good , so there is no need to include the action tiles for the two toggles in the program. Hope you pay a little bit more attention to my name next time. Quote
CafeJr Posted June 29, 2015 Author Posted June 29, 2015 Tharwat said: Good , so there is no need to include the action tiles for the two toggles in the program. Hope you pay a little bit more attention to my name next time. Opsss... Sorry... Typing too fast to thank you, Fixed!!!... Quote
CafeJr Posted July 2, 2015 Author Posted July 2, 2015 I did some changes. Update: (vl-load-com) (defun c:deti (/ dcl_id tipo bitola bitolas Sobe Desce userclick showimage files Path ) ;;; Modified by Tharwat 28.06.2015 ;; (if (and (< 0 (setq dcl_id (load_dialog "Deti.dcl"))) (new_dialog "Deti" dcl_id) ) (progn (defun showimage (file / a b) (start_image "img") (fill_image 0 0 (setq a (dimx_tile "img")) (setq b (dimy_tile "img")) 0 ) (slide_image 0 0 a b file) (end_image) ) (setq bitola "3/4\"" bitolas '("1/2\"" "3/4\"" "1\"" "1.1/2\"" "2\"" "2.1/2\"" "3\"" "4\"" ) Sobe 0 Desce 0 Path "C:\\************" files '("slide-C.sld" ;0 "slide-E.sld" ;1 "slide-X.sld" ;2 "slide-LB.sld" ;3 "slide-LL.sld" ;4 "slide-LR.sld" ;5 "slide-T.sld" ;6 "slide-BR.sld" ;7 "slide-LUR.sld" ;8 "slide-LBS.sld" ;9 "slide-LBD.sld" ;10 "slide-LLS.sld" ;11 "slide-LLD.sld" ;12 "slide-LRS.sld" ;13 "slide-LRD.sld" ;14 "slide-TS.sld" ;15 "slide-TD.sld" ;16 "slide-BRS.sld" ;17 "slide-BRD.sld" ;18 "slide-LURS.sld" ;19 "slide-LURD.sld" ;20 ) ) (set_tile "rb1" "1") (start_image "im") (fill_image 0 0 (dimx_tile "im") (dimy_tile "im") 5) (end_image) (start_list "Bitolas") (mapcar 'add_list bitolas) (end_list) (showimage (strcat Path "slide-C.sld") ) (action_tile "rb1" "(setq tipo \"C\")(mode_tile \"tog1\" 1)(mode_tile \"tog2\" 1)(showimage (strcat Path (car files)))" ) (action_tile "rb2" "(setq tipo \"E\")(mode_tile \"tog1\" 1)(mode_tile \"tog2\" 1) (showimage (strcat Path (cadr files)))" ) (action_tile "rb3" "(setq tipo \"X\")(mode_tile \"tog1\" 1)(mode_tile \"tog2\" 1)(showimage (strcat Path (caddr files)))" ) (action_tile "rb4" "(setq tipo \"LB\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0) (showimage (strcat Path (nth 3 files)))" ) (action_tile "rb5" "(setq tipo \"LL\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0) (showimage (strcat Path (nth 4 files)))" ) (action_tile "rb6" "(setq tipo \"LR\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0)(showimage (strcat Path (nth 5 files)))" ) (action_tile "rb7" "(setq tipo \"T\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0)(showimage (strcat Path (nth 6 files)))" ) (action_tile "rb8" "(setq tipo \"BR\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0)(showimage (strcat Path (nth 7 files)))" ) (action_tile "rb9" "(setq tipo \"LUR\")(mode_tile \"tog1\" 0)(mode_tile \"tog2\" 0)(showimage (strcat Path (nth 8 files)))" ) (action_tile "tog1" "(set_tile \"tog2\" \"0\")(showimage (strcat Path (if (= (atoi (get_tile \"rb4\")) 1)(nth 9 files) (if (= (atoi (get_tile \"rb5\")) 1)(nth 11 files) (if (= (atoi (get_tile \"rb6\")) 1)(nth 13 files) (if (= (atoi (get_tile \"rb7\")) 1)(nth 15 files) (if (= (atoi (get_tile \"rb8\")) 1)(nth 17 files) (if (= (atoi (get_tile \"rb9\")) 1)(nth 19 files) ) ) ) ) ) ) ) )" ) (action_tile "tog2" "(set_tile \"tog1\" \"0\")(showimage (strcat Path (if (= (atoi (get_tile \"rb4\")) 1)(nth 10 files) (if (= (atoi (get_tile \"rb5\")) 1)(nth 12 files) (if (= (atoi (get_tile \"rb6\")) 1)(nth 14 files) (if (= (atoi (get_tile \"rb7\")) 1)(nth 16 files) (if (= (atoi (get_tile \"rb8\")) 1)(nth 18 files) (if (= (atoi (get_tile \"rb9\")) 1)(nth 20 files) ) ) ) ) ) ) ) )" ) (action_tile "cancel" "(done_dialog)") (action_tile "accept" "(setq userclick t Sobe (atoi (get_tile \"tog1\")) Desce (atoi (get_tile \"tog2\")) Bitola (atof (get_tile \"Bitolas\"))) (done_dialog)" ) (start_dialog) (unload_dialog dcl_id) ) (if (< 0 dcl_id) (unload_dialog dcl_id) ) ) (if userclick (if (and (= desce 1) (= sobe 1)) (alert "ERRO: Selecione apenas Sobe ou Desce!") (progn (setq bitola (nth (fix bitola) bitolas)) (if (= sobe 1) (setq blockname (strcat tipo "-S" (if (= tipo "BR") " - Bucha de Redução Sobe" (if (= tipo "LUR") " - Luva de redução Sobe" " - Condulete" ) ) ) ) (if (= desce 1) (setq blockname (strcat tipo "-D" (if (= tipo "BR") " - Bucha de Redução Desce" (if (= tipo "LUR") " - Luva de redução Desce" " - Condulete" ) ) ) ) (setq blockname (strcat tipo (if (= tipo "BR") " - Bucha de redução" (if (= tipo "LUR") " - Luva de redução" " - Condulete" ) ) ) ) ) ) (command "_.-Insert" blockname "\\" 1. 1. 0. (strcat tipo "-%%C" bitola) ) ) ) ) (princ) ) DCL: Deti : dialog { //dialog name label = "Detalhamento de instalação" ; //give it a label : row { //*define row :boxed_radio_column { //define radio column label = "Ti&po:" ; //give it a label : radio_button { //define radion button key = "rb1" ; //give it a name label = "&C" ; //give it a label value = "1" ; //switch it on is_enabled = true ; } //end definition : radio_button { //define radio button key = "rb2" ; //give it a name label = "&E" ; //give it a label } //end definition : radio_button { //define radion button key = "rb3" ; //give it a name label = "&X" ; //give it a label } //end definition : radio_button { //define radio button key = "rb4" ; //give it a name label = "L&B" ; //give it a label } //end definition : radio_button { //define radio button key = "rb5" ; //give it a name label = "L&L" ; //give it a label } //end definition : radio_button { //define radio button key = "rb6" ; //give it a name label = "L&R" ; //give it a label } //end definition : radio_button { //define radion button key = "rb7" ; //give it a name label = "&T" ; //give it a label } //end definition : radio_button { //define radion button key = "rb8" ; //give it a name label = "BR" ; //give it a label } //end definition : radio_button { //define radion button key = "rb9" ; //give it a name label = "LUR" ; //give it a label } //end definition : boxed_row { label = "Sobe / Desce" ; :toggle { alignment = centered ; label = "&Sobe" ; key = "tog1" ; value = "0" ; } :toggle { alignment = centered ; label = "&Desce" ; key = "tog2" ; value = "0" ; } } } //end radio column : boxed_column { //*define boxed column label = "Bitol&a" ; //*give it a label : popup_list { //*define popup list alignment = centered; key = "Bitolas" ; //*give it a name value = "1" ; //*initial value } //*end list :image {height = 3; width = 0;aspect_ratio=0.8;color=0;fixed_height=true;key = "img";} } //*end boxed column } //*end row ok_cancel ; //predifined OK/Cancel : row { //define row : image { //define image tile key = "im" ; //give it a name height = 1.0 ; //and a height width = 2.0 ; //and now a width } //end image : paragraph { //define paragraph : text_part { //define text label = "Elaborado por:" ; //give it some text } //end text : text_part { //define more text label = "José Roberto dos Santos Junior."; //some more text - Credits to Kenny Ramage } //end text } //end paragraph } //end row } //end dialog Quote
