Hi there;
I would like to hide some objects in some viewports I choose while making them visible in model space and other viewports. I don't want to make this by using or changing layers, I just want to hide objects. Is that possible?
Thanks in advance.
By using or changing layers, do you mean that VIEWPORT LAYER FREEZE is not a suitable option?
The only way that I know of making objects invisible on a per-viewport basis is via viewport layer freeze (VPLAYER command is one way of accessing that).
It might be possible, depending on your needs, but layer management is by far the easiest way.
