Mark_Anif Posted June 24, 2015 Share Posted June 24, 2015 Hi all.. can help me how to convert 3d polyline to 2d polyline in autocad 2008? thank you.. Quote Link to comment Share on other sites More sharing options...
ttray33y Posted June 24, 2015 Share Posted June 24, 2015 have you tried the CONVERT command? Quote Link to comment Share on other sites More sharing options...
guran Posted June 24, 2015 Share Posted June 24, 2015 You can try this: https://apps.exchange.autodesk.com/ARCH/en/Detail/Index?id=appstore.exchange.autodesk.com%3aflatten_windows32and64%3aen I don't know if it works in ACAD 2008 though. Quote Link to comment Share on other sites More sharing options...
eldon Posted June 24, 2015 Share Posted June 24, 2015 Have you tried the Flatten command? Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 24, 2015 Share Posted June 24, 2015 Although flatten will change all of the vertices of a 3D polyline to 0.0, the entity will technically remain a "3D polyline" (the bitcode 8 is still set on group code 70). So you'll have a "2D" polyline as far as the "Z" coordinates all being 0.0, but if a application is testing this entity for a 3D polyline, that will still be true. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 24, 2015 Share Posted June 24, 2015 Hi all.. can help me how to convert 3d polyline to 2d polyline in autocad 2008? thank you.. I just tested this lisp routine in 2015 and it worked okay. Should work fine in 2008 also. Quote Link to comment Share on other sites More sharing options...
anniesmith Posted June 24, 2015 Share Posted June 24, 2015 You can use some of software tools available. And this video can also Quote Link to comment Share on other sites More sharing options...
Tiger Posted June 24, 2015 Share Posted June 24, 2015 EXPLODE -> PEDIT>JOIN ? If you wanna go the less fancy route without those new-finagled apps and stuff. Now, gerroff mah lawn! Quote Link to comment Share on other sites More sharing options...
Takis Tsiberis Posted September 26, 2020 Share Posted September 26, 2020 Select the 3D Poly, then do Modify -> Explode then select all the lines then (in the properties window) set "Start Z" to 0.00 (that is zero) also set "End Z" to 0.00 finally select all the lines then do Modify -> Join 1 Quote Link to comment Share on other sites More sharing options...
mohammad-hassan Posted September 28, 2020 Share Posted September 28, 2020 explode & join it Quote Link to comment Share on other sites More sharing options...
ahmedasem1 Posted February 20, 2021 Share Posted February 20, 2021 Thank you . i try it it working fine On 9/26/2020 at 8:38 PM, Takis Tsiberis said: Select the 3D Poly, then do Modify -> Explode then select all the lines then (in the properties window) set "Start Z" to 0.00 (that is zero) also set "End Z" to 0.00 finally select all the lines then do Modify -> Join Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 21, 2021 Share Posted February 21, 2021 If you dont have any arcs then the simplest is get Co-ordinates, erase, then create a new pline. Quote Link to comment Share on other sites More sharing options...
lrm Posted February 21, 2021 Share Posted February 21, 2021 @BIGAL per AutoCAD help "A 3D polyline is a connected sequence of straight line segments created as a single object. 3D polylines can be non-coplanar; however, they cannot include arc segments." No arcs, Explode,flatten join. or with osnap set to end you can use pline and pick the 3dpoly vertices in order. Vertices of the 3dpoly that you pick will be projected to a 2D plane that is parallel to the current xy plane and that contains the first vertex you digitize. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 22, 2021 Share Posted February 22, 2021 Yeah forgot about no arcs, would be pretty easy to add a trans so recreated in world UCS. Just strip z, looking at the link. Quote Link to comment Share on other sites More sharing options...
Trudy Posted February 22, 2021 Share Posted February 22, 2021 Something i extract from one code. command is 3dpto2d Work only for Plines without ARCs (defun LM:group-n ( l n / r ) (if l (cons (reverse (repeat n (setq r (cons (car l) r) l (cdr l)) r)) (LM:group-n l n) ) ) ) (defun c:3dpto2d (/ listt XY) (setq sel (ssget '((0 . "POLYLINE")))) (repeat (setq i (sslength sel)) (setq Vname (vlax-ename->vla-object (ssname sel (setq i (1- i))))) (if (equal (vlax-get Vname 'ObjectName) "AcDb3dPolyline") (progn (setq coord (vlax-get Vname 'coordinates)) (setq listt (LM:group-n coord 3)) (foreach x listt (setq XY (cons (list (car x) (cadr x)) XY))) (ENTMAKE (APPLY (FUNCTION APPEND) (CONS (LIST '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(67 . 0) '(410 . "Model") (cons 8 (getvar 'clayer)) '(100 . "AcDbPolyline") (CONS 90 (LENGTH XY)) (if (= (vlax-get Vname 'Closed) 0) (cons 70 0) (cons 70 1)) ) (MAPCAR (FUNCTION LIST) (MAPCAR (FUNCTION (LAMBDA (XY) (CONS 10 XY))) XY) ) ) ) ) (setq XY nil) ) ) ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 22, 2021 Share Posted February 22, 2021 27 minutes ago, Trudy said: Work only for Plines without ARCs Which is fine, since 3D polylines cannot contain arcs anyway. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 23, 2021 Share Posted February 23, 2021 I do believe CADTOOLS.exe has 3DPline to Pline. Quote Link to comment Share on other sites More sharing options...
Hanter Thomsom Posted June 6, 2023 Share Posted June 6, 2023 (edited) On 2/22/2021 at 3:09 PM, Trudy said: Work only for Plines without ARCs Thanks its realy worked Edited June 6, 2023 by Hanter Thomsom Quote Link to comment Share on other sites More sharing options...
