CADMAN57 Posted June 22, 2015 Share Posted June 22, 2015 Good morning... I'm creating a set of new utility line types for our surveying department. Water lines, sewer, and so forth. They will all have a "W" or "SS" in them, depicting the type of line. I want them to look differently from our civil department's lines, so I am trying to make them with an oblique text style. I created a new text style called Simplex, and used the simplex.shx font type with it. However, the line styles I created don't recognize that I put an obliquing angle on the text style. And, of course, the simplex.shx doesn't allow you to put an obliquing font style on. My problem is that these drawings might be sent to clients who don't have civil 3D, but are using other software, so I don't want to stray from the simplex.shx too far. Anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
eldon Posted June 22, 2015 Share Posted June 22, 2015 Try writing some text into the drawing using your obliqued style and then try drawing a line with your new linetype. Quote Link to comment Share on other sites More sharing options...
CADMAN57 Posted June 22, 2015 Author Share Posted June 22, 2015 Already tried it...thanks though Quote Link to comment Share on other sites More sharing options...
eldon Posted June 22, 2015 Share Posted June 22, 2015 Did you do a Regen? because that is what worked for me. I will post a picture in a while. Quote Link to comment Share on other sites More sharing options...
CADMAN57 Posted June 22, 2015 Author Share Posted June 22, 2015 I did...text in both mtext and dtext...nothing Quote Link to comment Share on other sites More sharing options...
eldon Posted June 22, 2015 Share Posted June 22, 2015 I started a new drawing from scratch, and created a Text style called simplex using a 15 degree oblique angle. Then I made a layer with a linetype using the simplex textstyle. The first picture is when I drew a line only. The second picture is with some Dtext and a regen. All lines drawn after the Dtext have the obliquing. My AutoCAD must be more magic than yours Quote Link to comment Share on other sites More sharing options...
CADMAN57 Posted June 22, 2015 Author Share Posted June 22, 2015 huh...I don 't get that at all....what version are you in? I'm in 2013... This keeps up, you might be doing my standards for me... Quote Link to comment Share on other sites More sharing options...
eldon Posted June 22, 2015 Share Posted June 22, 2015 I can only imagine that AutoCAD has been "improved" since my 2002 version. Quote Link to comment Share on other sites More sharing options...
CADMAN57 Posted June 22, 2015 Author Share Posted June 22, 2015 Right...with all the cool old stuff it used to have weeded out....like the scale in place option...still miss that one...thanks anyway, eldon...my search continues... Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 22, 2015 Share Posted June 22, 2015 I doubt very much it has anything to do with the version of AutoCAD you are running compared to the version eldon is running. You have any idea how long the Simplex font has been a part of AutoCAD? In your linetype definition file did you set the relative rotation? Quote Link to comment Share on other sites More sharing options...
CADMAN57 Posted June 22, 2015 Author Share Posted June 22, 2015 Well, I know it was in existence in 1988 when I started all this...that was Softdesk 10. And of course I did. This is about fonts... Quote Link to comment Share on other sites More sharing options...
eldon Posted June 22, 2015 Share Posted June 22, 2015 To go back to your first post ...... And, of course, the simplex.shx doesn't allow you to put an obliquing font style on. I managed to put an Oblique Angle in the text style Effects, not in the Font Style. Is that your problem? Quote Link to comment Share on other sites More sharing options...
CADMAN57 Posted June 22, 2015 Author Share Posted June 22, 2015 no....the obliquing angle is there. the problem is the line type doesn't recognize that the obliquing is there. Quote Link to comment Share on other sites More sharing options...
eldon Posted June 22, 2015 Share Posted June 22, 2015 if you could post a drawing with only one line of your linetype, I could open it up with my version, and see if I get the same effect. Quote Link to comment Share on other sites More sharing options...
CADMAN57 Posted June 22, 2015 Author Share Posted June 22, 2015 good of you to ask, but if you're running 2002, I doubt that's possible. 2002 and 2013 don't play together well... Quote Link to comment Share on other sites More sharing options...
eldon Posted June 22, 2015 Share Posted June 22, 2015 Living as I do with an older version, I have DWG Trueview to convert for me. But possibly to save some time, here is my linetype file: *AG_SVY,Survey boundary ----SVY----SVY----SVY----SVY----SVY----SVY-- A,.5,-.2,["SVY",simplex,S=.1,R=0.0,X=-0.1,Y=-.05],-.25 Quote Link to comment Share on other sites More sharing options...
eldon Posted June 23, 2015 Share Posted June 23, 2015 There seems to be a sudden hush by the OP. Are we to assume that there was a slight error in the OP's linetype definition? Feed back would be useful for anyone following this thread. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 23, 2015 Share Posted June 23, 2015 Maybe he went on holiday? Quote Link to comment Share on other sites More sharing options...
CADMAN57 Posted June 23, 2015 Author Share Posted June 23, 2015 Neither, actually...found a shape file (gbeitc.shx) that is standard issue in cad, and has an oblique angle out of the box. Works in the line style just fine...thanks for all your attempts....really do appreciate it.... Quote Link to comment Share on other sites More sharing options...
eldon Posted June 23, 2015 Share Posted June 23, 2015 Do you want to find out what went wrong with your initial linetype? Perhaps you could post your linetype definition file. Even with the new font, I had to put some text into the drawing first before it behaved itself. Quote Link to comment Share on other sites More sharing options...
