tazzzz Posted June 5, 2015 Posted June 5, 2015 Hello all, I created a rectangle with 3 attributes inside (A1; A2; A3)-in order to modify the rectangle for the right dimensions that represents a future block. When I create a block, 8 out of 10 times the prompt to edit the attributes shows them in right order: A1; A2; A3. Sometimes Attributes come in random order. Do you know why is this happening and what can I do to prevent this? I know how to fix the block with BATTMAN but I don’t like to come at this point Thanks. Quote
Cad64 Posted June 5, 2015 Posted June 5, 2015 When you create the block, you need to select the attributes in the order you want them to display. Select A1 then A2 then A3, etc. Quote
tazzzz Posted June 5, 2015 Author Posted June 5, 2015 I tied to select them in desired order but is not working. What I just noticed is that is doing this for the first block created after I open the drawing( after that is seems to work fine). Thanks Quote
nukecad Posted June 6, 2015 Posted June 6, 2015 To re-order the attributes, explode the block then use DRAWORDER to bring them to the front in the order that you want them to appear in the attributes dialogue box. (As you bring each one to the front of the order it goes to the bottom of the ‘attedit’ table; so you must do ALL of the attributes). Once you have them in the order you want remake the block. Quote
